Door clicker does not work
I forgot the model Cadi my neighbor has, can find out. Their door clicker stopped functioning. Are all the GM door clickers basically the same ( function wise) can the clickers and the unit be reprogrammed. I have seen the clickers on sale on ebay. Anyway my neighbors stopped working, they have not tried their spare clicker.
Re: Door clicker does not work
No, they aren't all the same. There's two series of numbers on the back of the remote. The replacement one has to match those numbers exactly. And depending on the model of Cadillac, it will have to be programmed at a dealer.
Have you checked the battery in the remote?
2000 Cadillac STS 2005 Cadillac Escalade 2008 Triumph Sprint ST 1050 ABS |
let me ask you a generic question about remotes. If I lose one, would i have to buy one with this same number on the back or buy a new set and have the dealer reprogram them ? can the remote be reprogrammed ? |
I had a clicker once that I ruined by having it in my pocket then getting in our pool. I replaced it with a generic and reprogrammed it. There were directions for programming that came with the replacement clicker. The problem that I have, is the old clicker only worked intermittently (I had changed the battery so the battery was not the problem). I thought a new clicker would solve the problem. I think I have some sort of intermittent problem with the receiver, but I don't know where to start.
ok, so if i get two new remotes they should both have the same code on the back , step 2 is take them to the dealer and have the receiver or is it the BCM ? programmed with the tech 2 scan tool.
Let me ask you an off topic question. We just bought a new Malibu Maxx that has pass lock. I think there is a chip in the key, what do i have to do if i want to get another spare key ? |
As for the Mailbu, the dealer will have to get the correct key code from the VIN to make a new key for it. It will probably be pricey, like $50 or more.
