Old 09-08-2006, 06:36 PM
bratt bratt is offline
Question one tire makes alot of noise on my ford f350
i have a lifted f350 with wrangler all terrain tires military
anyhow it seems all 3 tires make noise but wow the right front tire makes alot of noise while driving.
i checked the tire pressure and its fine.
its always made noise since i bought it and i havent had any problems but what can i do to shut it up its so loud.
Old 09-09-2006, 07:20 PM
cyderus cyderus is offline
Re: one tire makes alot of noise on my ford f350
have you had the front end checked and alignment checked.
Old 09-09-2006, 08:00 PM
the alignment is perfect the truck drives straight no problems
Old 09-10-2006, 09:04 AM
BAMB136 BAMB136 is offline
Have u checked the wheel bearing or the tire or put the tire on a differint axel to see if it still makes the noise
Old 09-25-2006, 02:37 PM
Ncgreasemonkey's Avatar
Ncgreasemonkey Ncgreasemonkey is offline
The first thing to do about this problem is rotate the noisy tire to another spot, and see if the noise moves. If it does, you got a bad tire wear pattern that's causing the noise. (Note, this isn't always due to an alignment issue, some tires just have a tendancy to wear bad. Ex. continental Contitrac's like on Tribute's and Escapes) If the noise stays in the same position, odds are, you've got a bad wheel bearing.
