Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 09-08-2006, 06:23 PM
s10chevybogger s10chevybogger is offline
350 engine problems
i have a 350 in my mud truck and when i start it it runs good at an idle and when i hit the gas it dies can anyone help me out or gimme a few ideas whats wrong with it if ya could it will be greatly appreciated
thanks
Ed
Old 09-08-2006, 06:31 PM
maxwedge maxwedge is offline
A990 racer
Re: 350 engine problems
Got spark when it dies, will it restart right away, does it do this all the time hot or cold. Will it restart if you spray carb cleaner into the carb confirming it is fuel problem. You have not provided even the basic info or preliminary diagnostics for us to provide any meaningful help.
Old 09-08-2006, 06:37 PM
sorry about not putting in the info i got side tracked but anyways it does restart after it dies i dont know its wierd like i can get the revs up to 2 grand and then after that it just quits the carb is a rebuilt one so i dont think it needs to be cleaned i havent had it in the mud yet so nothing is dirty
Old 09-08-2006, 06:45 PM
A990 racer
Lightbulb Re: 350 engine problems
Blocked in line filter, bad fuel pump, kinked fuel line ,filter in tank clogged, lots of possibilities here. Some carbs have a filter right in the inlet fitting but again, we don't know the carb is, slow down here and think about what a total stranger online needs to know to provide help.
Old 09-08-2006, 07:59 PM
the carb is a quadrajet 4 barrel and the motor is a 350 throttle body converted into a carburated with a inline fuel pump the filter shouldnt be clogged its all brandnew and the lines arent kinked. I just dont know what it is it will start and run fine at idle - 2 gs and then when you go to mash the gas to hear the open headers it dies i just went to my buddies and got another carb and it still does the same thing maybe i should trash the motor? i have a 400 small block i can put in it i dont know im getting so frustrated that i just want to burn the freaking thing
Old 09-08-2006, 08:30 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Well that mashing-the-gas thing is kind of important. It could simply be a case of the secondary air valve needing to be readjusted. If it gets too much air too soon, the mixture will lean out and the engine will fall on its face.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
