Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-08-2006, 06:10 PM
northriverflames northriverflames is offline
Send a message via MSN to northriverflames
NEED HELP ASAP Motor Build (Rods/Rod Caps)
Hello
Im in the process of building my new motor and have had my pistons and rods checked by a machine shop. They informed me that they may have gotten two of the rod caps mixed up with the rods. Iv been searching and cannot find any info. Does it matter what cap goes on what rod? Why would there be a difference when there is going to be a bearing inbetween the rod and the crank? Any help would be awesome
Tony
2000 Chevy Silverado 1500 4x4 Extended Cab.
1996 Pontiac Sunfire GT 5 Spd.
1992 Plymouth Laser RST AWD 5 Spd.
Old 09-08-2006, 08:57 PM
E-Klips E-Klips is offline
Banned
Re: NEED HELP ASAP Motor Build (Rods/Rod Caps)
Because whether there is a bearing in there or not, it still needs to be perfectly round. So if you mix some rod caps up that could throw off how round the rod journals really are. Causing it to be loose on one side and really tight on the other, in return would spin a bearing.
Old 09-08-2006, 09:35 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Uh-oh! Yeah man, you always want to mark that shit well. I dont know for sure, but I think the rod/rod cap are cast as a singe unit, they have the rod jounal hole bored out, then have the caps cut off. Well, they dont always get the journal hole in the exact same spot so when you change them around you end up with goofy holes. I dont know man, sounds to me like you are boned. I would just get some new ones and not risk spinning a bearing. Trust me, hearing your piston slap the head due to the lack of bearing is about enought to make you cry. It threw me into like a 4 day slump, all I did was mope in the basement and destroyed my motivation for the DSM. Dont worry though guys, now that I am away from it and have another POS to rip apart, I wish all I had to do was go work on the bitch.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-09-2006, 07:42 AM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
If this machine shop is set up properly they should beable to put the caps on and run a dial indicator on them to see which ones match up.
Something like resizing them, but this process would be just to find out what cap is the correct one
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
