Old 09-08-2006, 05:30 PM
muff34 muff34 is offline
pre ignition Knock
Anyone ever hear of Pre -Ignition knock. Got 4.3 v-6 that seems to have this condition, only when it is warm tho . 230,000 km on the engine . if you are familiar with this my question is . Can anything be done about it and if not will damage to engine occur to engine over time. I do know that the timing is computer controlled and cannot be reset.
Thanks Muff
Life Is A Highway ,Enjoy The Ride
Old 09-08-2006, 06:53 PM
maxwedge maxwedge is online now
A990 racer
Re: pre ignition Knock
The egr system would be the most common cause of this, inop or passages clogged. Not mentioning the year here as this was left out, but is it an obd11 truck?
Old 09-08-2006, 06:59 PM
ya sorry 2000 silverado. If there is a problem there wouldn`t the chk engine light come on tho. So far it is not.
Old 09-08-2006, 07:05 PM
A990 racer
A bi -directional scanner can command the egr system on, when this happens at idle the engine would almost stumble or stall, if not it is not working, only professional highline scanners can perform this test. Also check for pending codes. You can also check on the scanner, for knock sensor operation if so equipped.
