Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 09-08-2006, 12:09 PM
Rebel Racing 3's Avatar
Rebel Racing 3 Rebel Racing 3 is offline
Slave cyld. on 94 ford f 250
Ok so i have a 94 f 250 powerstroke, and the other day i blew the slave cyld. out so i replaced it and now i cant get the damn thing to bleed any ideas????
Old 10-13-2006, 02:36 PM
rhandwor rhandwor is offline
Re: Slave cyld. on 94 ford f 250
These are very hard to bleed some people pump and pump about 20 min. I would purchase a new pump oil can. Flush out with break clean after it is clean and dry. Fill with brake fluid. Install a piece of vacuum hose on it. Open the bleed and pump until fluid runs out of the slave master cylinder. Shut off while pumping this gets most if not all the air out. You may have to rebleed but at least you can get the fluid moving. If you have a vacuum pump with a bottle you can pull fluid this way.
Old 10-28-2006, 05:45 PM
wafrederick wafrederick is offline
Banned
They are pain in the butt to bleed and take a long time.You will to have a friend to pump the clutch pedal
