Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-08-2006, 11:49 AM
1996EclipseRS 1996EclipseRS is offline
Transmission Problem PLEASE HELP!!
Facts
-The Transmission has shifted into a default mode because an electrical sensor or input signal has failed
-Shifts into this default mode after the 1st initial start-up and first foward motion.
-Electrical connectors are:
-input speed
-output speed
-solenoid and pressure switch
I need help ASAP! This car is my only mode of transportation. I highly depend on it!
THANKS!!
420A
JE Forged Pistons 10:5, Crane Super Street Performance Cams, Crower Connecting Rods, Crower Valve Springs, Port & Polished Head, A'PEXi SAFC II, DigiMoto Datalogger + more, Prothane Motor Mounts, Ebay Header =(, Stock Exhaust, busted driver side window, stolen SAFC(tear), blown tranny
-1984 Mercedes Turbo Diesel 300CD (270k)
-1992 Ford F-150 302 (180k)
Old 09-08-2006, 11:59 PM
Re: Transmission Problem PLEASE HELP!!
anyone? ...
420A
Old 09-10-2006, 07:06 PM
so noone can help me..thanks
420A
Old 09-10-2006, 07:57 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Could be a minor or major problem.
You need to find a good repair shop with a transmission capable scanner and read out transmission data and get the codes.
The codes and data will point you in the right direction.
If you get any codes post back code no.
MT
MT
