Old 08-28-2002, 11:55 AM
lotus_man's Avatar
lotus_man lotus_man is offline
Molded in belts
I'm in the process of building Tamiya Jaguar XJR9-LM. The seat has molded in belts, which I want to remove and replace. Any good tips on removing them. I've tried sanding and scrapping with little luck due to the curve of the seat. Is there a better way, or should I just percivier?
Old 08-28-2002, 12:13 PM
freakray freakray is offline
AF Modelrater
Lotus_man,
If you have a dremel, it would make it a lot easier and quicker, just take off small amounts at a time, you can always even things up with putty. If you don't have a dremel, then I think you are stuck with persevering....
Ray
AF User Guidelines
Old 08-28-2002, 12:45 PM
flyonthewall's Avatar
Car Mod guy
A Dremel or any motor tool is by far the best way, there are plenty of types available and some at a fraction of the cost of Dremel which are fine for model makers who are likely to use them very little.
Old 08-28-2002, 12:49 PM
Daryl's Avatar
Daryl Daryl is offline
is a router the same as a dremel? I think Fujimi makes one.
edit-i meant hasegawa
Left is right. Right is wrong.
07 Cabin Mildew/Mold problem Rodie40 Camry/Camry Hybrid/Vista 3 10-18-2009 12:10 PM
limousime 1.9 TDI 1999 ventilator belt noise kmiki '97+ 0 04-20-2009 02:40 AM
99' Ram Quad Cab -I Need Seat belt Help PLEASE!! nrosssr Ram Pickup | Ram SRT10 0 03-30-2009 05:42 PM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
How to Tighten Tensioner on Serpentine Belt - 05 G6 donnap1957 G6 0 02-26-2009 09:01 PM
