worth fixing
hi everyone i am new to these forums i am looking at gettin a new car i have a few friends with shops so tools are easily accesable. anyways to the point i am looking at buying this 95 3000gt off this kid he has had it sitting around his house after he wrecked it a year ago i am going to go see it first hand this weekend but was sent a few pictures. i am wondering what you guys think is it worth me picking up for around 2k or so let me know thanks.
Re: worth fixing
A) is there any frame damage...that is a huge factor to consider
B) what all needs to be replaced, ie, is hte engine screwed up? C) are you fixing it yourself, or do you plan to pay somebody? I know you said you have friends with shops, but I was just curious if fixing this was within your mechanical ability. If it were me, and I could get that car really cheap, I would then start looking for a vr4 front clip. You could use any parts off the vr4 front clip, PLUS, you could do the TT conversion. 2 birds...1 stone
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Re: worth fixing
Yeah, as long as there is no frame or engine damage it wouldn't be a bad buy since it looks like it would only need a new front clip, fenders, and hood.
Re: worth fixing
from the pictures it looks as if you'll need a new drivers front fender, front bumper, headlights, turn signals, crash bars, .....and the front part of the frame has been removed! it attaches at the edges just outside the radiator.
i dunno, it looks like it probably has frame damage. that's probably the reason it has been sitting there, b/c its not driveable. BUT, you can try to get the frame aligned back within spec. but to find those frame pieces you'll have to go to a junkyard. if you're friend has all the tools, and you can get it for UNDER $2k, then it MIGHT be worth it.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Re: worth fixing
all the work is within my capabillities i have been working on cars for about 5 years now including body work. i have done my eclipse conversion to a turbo and also my friends 420a to 4g63 conversion so nothing is out of the question
i have been told that the frame is not bent and the motor runs just has been sitting for about a year and needs basic maintance to get running again besides the radiator needing a new support/ headlight buckets. all in all i am just not sure if it will be worth me fixing for now to have a new daily driver and i am thinking about parts from around 600+ if i get all from junkyard 2500+ if i buy brand new and do a 99 conversion at the same time |
