Old 09-08-2006, 04:39 AM
mxz600 mxz600 is offline
1997 Taurus only clicking, no start
Started like the battery was low yesterday morning. Drove to work, no problems.
Went to leave work and wir, wir, wir, click, click, click. Dead battery I think, wrong, jumped it and no dice. Thought maybe the battery was bad (3 years old). Got a ride home and brought back a good battery. Hooked it up and same thing. No spark when putting cables to the battery. Is the starter bad? Solenoid should be good since it's clicking right? Tap on the starter and it will turn over for split second and then start clicking when I hit the key.
Any and all help is greatly appreciated.
Jay
Old 09-08-2006, 05:43 AM
Millermagic Millermagic is offline
Re: 1997 Taurus only clicking, no start
Might be a bad ground or bad cables. I'd check and see if the ables are connected good andin good shape.
- Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers -
As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee!
Old 09-08-2006, 06:31 AM
Cables are good and ground is good.
Jay
Old 09-08-2006, 01:07 PM
KimMG KimMG is offline
AF - Advisor
The bushings in starters wear and bind prevent the starter motor from turning. Have you tried tapping on the starter motor itself with a hammer.
Old 09-08-2006, 05:14 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
mzx600 does mention "Tap on the starter and it will turn over for split second and then start clicking when I hit the key" but I'm not really clear what they mean. Tap on the starter, turn the key to start and it will turn over for a split second the start cliking? It shouldn't start to turn over before hitting the key.
If that is the case, I would agree that your starter motor is probably bad. What do the interior lights or headlights do when you try to start the car? Is the clicking clicking as long as you hold the key in the start position or just one click until you release the key and try again?
-Rod
