94 grand am abs light
I have a 94 grand am with the abs light on. Is there a way to get the code with out a tech 1? thanks in advance. Bill
Re: 94 grand am abs light
Not sure about getting the codes on it. However, past experience, ABS light showed up on our 1994 Pontiac Grand Am. I cleared it by disconnecting the battery and the two electrical plug abs connector overnight and cleared the ABS light. The ABS light would keep coming up anyway. I was clearing for a week and then I got stranded, my alternator was toasted. I replaced the Alternator and I did not have the ABS light coming on anymore.
This is what I have discovered so far based on my experience. When the ABS light keeps coming on by itself for no reason and if you clear the ABS light and keeps coming back, more than likely that the alternator is failing. Have your alternator tested at Autozone. You don't have to remove the alternator to test it and they can also test your battery as well without removing them. |
Everything Goes Off When Started But Amber Light Goes On When You Start Rolling. Poss. Bad Sensor But Need To Get Code And I Do Not Want To Spend Big $$$ For A Meter. Was Hoping I Could Get Code Another Way Like Blinking Dash Lights????
You've got a '94.. Can't you use the jumper trick, or does it not pull ABS codes? It sounds like a sensor problem. You could do a visual of the sensors and wiring and probably find the problem yourself..
2007 Certified DaimlerChrysler Service Technician... True blue GM at heart. |
You can flash ABS codes on OBD 1 systems but not if its a hybrid OBD1 , does anyone know if 94 was a hybrid system in the Grand am?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) Last edited by FormulaLT1; 09-08-2006 at 06:58 PM. |
94 and 95 are hybrid systems. Sucks, I have a 95 and have to have the dealer get codes for me.
Rusting out Honda Civic $900 Fart cannon muffler: $300 Assorted stickers advertising products you'll never own: $50 Having your @ss handed to you by a brick shaped suv: Priceless. Yup, I own the suv. |
Thanks Guys. I was affraid of that but that was my conclusion to.
willyrazz, you can try to extract the code with the flashing light, some 94's and 95s are OBD1 not a hybrid. Most are but not all!
Heres the link with the proceedure. Grand AM trouble codes I can tell you right now, One of Your wheel speed sensor(s) are most likly no working, indicated by the ABS light. If they hav never been changed, I'd change both.
1999 Grand Am SS 3.4 OHV
Just was looking at MilzyMotorsports, they hav a convertion kit for 94-95 to OBD II, chekc it out!
http://www.milzymotorsports.com/miva/merchant.mvc?Screen=PROD&Store_Code=MMS&Product_Co de=OBD2CONV A little more than what you would spend at the stealership
