Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-07-2006, 07:16 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
14b turbo install?
I dont have the 1g water lines to complete the turbo install. my question is, since the 1g water obvieosly comes off of a 1g, do I need to do modify the 1g water lines? I dont think so but I just want to make sure before I anything. thanks
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 09-07-2006, 11:19 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: 14b turbo install?
You can use either 1g/2g lines. The last 2 14b's I've had needed slight bending (use a small phillips). Just remember to get 6 copper crush washers from the Mitsu parts department. 4 for the coolant banjo's, 2 for the oil feed banjo.. Don't forget the oil drain tube gaskets & be carefull not to over tighten them, they strip very easy and are a pain in the ass to tap out to a 20UNC 1/4 size... Trust me...
DSM geek
