Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 09-07-2006, 06:46 PM
Matt from TVT Matt from TVT is offline
1995 Tacoma problem, any ideas?
I have a 1995 tacoma excab 2wd 2rzfe with 268000 miles.
Check engine light code po340. Put on new distributer housing with cam position sensor. That did not fix the problem, same code still there. Cleared it 2 times after new parts. Any body seen this before?
Thanks for you're help.
Matt
Wiring checks out.
Symptoms; 10 mpg drop in gas mileage, Sometimes a stutter at idle, a miss on 1 cylinder at various times,speeds and rpm with a load on the motor.
Old 09-08-2006, 01:07 AM
TcmaBoy's Avatar
TcmaBoy TcmaBoy is offline
AF - Advisor
Re: 1995 Tacoma problem, any ideas?
Have you run the wires to and from the sensor?
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
Old 09-11-2006, 01:58 PM
Found the problem in the wireing harness
