Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-07-2006, 03:28 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
having a wee bit of a problem.
So my lovely 91 GSX has decided to not like me at all and never run. Here's what's wrong.
It started when I was driving it home from having picked it up I was coming off the interstate and the RPMS dropped real low and the car started to die well it did die. But I was able to start it right back up and continue on. Well now it's doing that same thing.
I can start the car right up and it will idle fine, as I have sat there and let it idle for ten minutes and the car idles like a champ and I get no lights. But as sooon as I start to drive somewhere the car will die on me. The rpms drop real low, all the lights come on and the car just dies. And alot of times I won't be able to get it started again until it sits for a bit. Than it will start up just fine but if I try to drive same problem. Now the wire than runs the tps sensor was frayed so I replaced that but it still does the same thing. So anyone have any idea's as to what it could be? I really need to get this car running so I can drive it around. I'm tired of it being dead.
1991 GSX 2.3 Stroker
Old 09-07-2006, 03:35 PM
Bodack Bodack is offline
Send a message via AIM to Bodack
Re: having a wee bit of a problem.
Could be a fuel delivery problem under a load. But I have no clue where to start diagnosing it. Maybe you could check the injectors? Does it do ok when it's sitting still but you rev it?
1993 Honda CBR900RR
1990 Talon TSi AWD - Sold
1990 Laser RS turbo - Sold
1993 Eclipse GS - Sold
Old 09-07-2006, 03:45 PM
defiancy's Avatar
Yep.
Old 09-08-2006, 02:13 PM
defiancy's Avatar
bump because I really need help with this, any Idea's or suggestions?
Old 09-08-2006, 04:01 PM
Really wish I could help out...it still sounds like fuel delivery like the the injector can't operate under load. Have you checked them yet? Are the plugs and wires all good? I wish I could find my haynes manual...
1993 Honda CBR900RR
Old 09-08-2006, 08:13 PM
defiancy's Avatar
Plugs, wires are brand new. So is the fuel filter.
Old 09-08-2006, 08:16 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Sounds to me like the CAS is shot... They will idle fine but once you put a load on the motor it freaks out and doesn't know what to do.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 09-08-2006, 10:48 PM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
When i first bought my talon, it did the exact same thing. I would idle PERFECTLY, but after I drive it around (even if I move it 10 feet) and then push in the clutch (to slow down) the car would bump down to ~200 RPm and then die.
Turned out to be the PCV valve, mine was completely shot. I could blow right through it in both directions. Changed it with an OEM one and has never done it since. Counting that it is like $5 from the dealership, it will not hurt to change.
GL
Old 09-09-2006, 02:42 AM
defiancy's Avatar
GL
Did you get lights when it died, like the CEL and such?
