Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 09-07-2006, 03:07 PM
jdq jdq is offline
cat
Can u still pass emmissions with high flow cat.I smelled sulphur the other day does this mean my catalytic converter needs replaced.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 09-17-2006, 07:21 AM
jdq jdq is offline
Re: cat
bump
Old 09-18-2006, 12:29 PM
neon_rt's Avatar
neon_rt neon_rt is offline
Re: cat
Yes and no, to the Cat question.
In Federal emission states you can use just about any ODB2 approved high Flow CAT. In states that use the California standard you have to get a replacement that is approved by CARB (which very few are). You are stuck (in most cases) with using OEM CATs in California and the 4 other states that use the CARB standards.
The sulphur smell is usually caused by very lean fuel mixture. Many of the new trucks I've seen (smelled) have this problem. They have to idle at this lean mixture to pass emissions. Passing emissions is more important than stinking. Although, I would have a mechanic run an emissions test to see what is going on with the engine and if it is running within normal parameters.
Old 09-18-2006, 05:49 PM
jdq jdq is offline
Re: cat
So doesnt necessarily mean my cat is pooched, what can I do to for this lean as I am going to sell the car, thanks for reply.I prefer not to spend too much.Will a higher octane gas clean it up.
