| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
2003 Sunfire headlight issue
My daughter has a 2003 Sunfire and we noticed the headlight bothe dims and highs on the driver side were dim so I replaced the bulbs-STILL dim. I am thinking there must be a poor ground in the circuit am I on the right track??
Re: 2003 Sunfire headlight issue
a bad ground is very possible, also a bad DRL relay can cause the headlights to do some weird things, you may check that too
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM, 1981 Fairmont 6cyl 3 speed 1978 Ford Ranchero GT 302 with a few goodies |
where is the drl relay on a 2003 sunfire?
There is one gray block type plug behind when the headlamp assembly comes out. But under the hood with the other relays there is nothing. And how can you test it? I am also going to look over the wire harness this weekend. I have to take the wheel and splash guard off to follow it. |
did you try the fuse box? thats where it is in my 98
I will look again but I did not see it listed on the cover. There is one item located behind the headlamp assembly that I thought may be it. It is a square gray block about 1 to 1.5 inches square and is fastened to the sheet metal with a plastic pop rivet. Although this may also NOT be it. The Haynes manual is no help either.
Thanks |
I'm not sure where the relay is located but I'm pretty sure its looks like what you described, small gray block.
Like check continuity or anything? If they don't cost much I could just replace it to see if that is it but that might be throwing cash away. It would be the easy fix if it was the culprit |
^ you could just use a test light im sure to see if its bad or not.
