Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 09-07-2006, 11:17 AM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
WD-40 as cleaner
Has anyone tried to use WD-40 on their dash to clean tape adhesive? Will it eat through the plastic dash? I tried isopropyl alcohol, but it doesn't clean it all the way.
Old 09-07-2006, 12:09 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: WD-40 as cleaner
WD40 is a lubricant/anti-sieze product. I dont think using it as a "goop remover" is a good idea, or even logical. Perhaps try some gunk off, or some other product that is designed to take off sticky messes...i know they sell them.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 09-07-2006, 06:24 PM
clipse_thumper's Avatar
clipse_thumper clipse_thumper is offline
Send a message via AIM to clipse_thumper
try brake cleaner
Old 09-07-2006, 06:27 PM
my99cavy's Avatar
my99cavy my99cavy is offline
Send a message via AIM to my99cavy Send a message via MSN to my99cavy
http://www.automotiveforums.com/vbul...d.php?t=609312
Note where it says, ''Removes all traces of duct tape'' so I think it will work just dont use a lot on it.
Old 09-08-2006, 06:11 AM
Absintheuphoria Absintheuphoria is offline
Send a message via AIM to Absintheuphoria
brake cleaner?
2000 Eclipse GT (stock)
Pimped out my car with a car alarm. I'll blow yours out of the water with my list of mods...
Old 09-08-2006, 07:56 AM
rubix777's Avatar
I googled and found that mayonnaise can remove adhesive too.
As for brake cleaner.. let me know what happens when you try it on your dash.
Old 09-09-2006, 06:04 AM
acid might do the job too, that or a shotgun
Rob Castle
Old 09-10-2006, 04:04 AM
That's pointless. Just take a 120mm round, wire it up to your starter, and harness it over the spot you wish to remove. Start up the car and run...
