starter replacement
I need to replace the starter in my 2001 cavalier. Any tips or pitfalls or potential problems I should be aware of? Is it easy to get at or do I have to remove other parts to get at it? Where abouts is the starter located? (I haven't even looked at it yet)
Re: starter replacement
under your car kinda like center ish. just make for damn sure that you keep the negative and positive lines seperate so you put them on right, i use color coded zip ties, (red and black) and please please disconnect oyur battery first
Don't forget to remove the nut on the top side of the front starter bolt first, or you'll snap the bolt every time..
2007 Certified DaimlerChrysler Service Technician... True blue GM at heart. |
... last time I took mine off it was just two bolts holding the starter on
Some probably are, but a few I've worked on had a nut... I cussed myself when I figured out what I did....Got in a hurry.
