Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-07-2006, 09:50 AM
Bannon7414 Bannon7414 is offline
Send a message via AIM to Bannon7414
Jack Capacity
Some asshole slashed one of my tires at school, and i don't have a jack. What size do I need to buy? Will a 2 1/4 ton jack be good enuff for lifting my Caprice?
1994 Chevy Caprice 350 5.7L Police Package
Old 09-07-2006, 10:35 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Jack Capacity
Yes.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-07-2006, 05:31 PM
HLandin's Avatar
HLandin HLandin is offline
Re: Jack Capacity
Depending on model year, your Caprice will weigh between 3900 and 4300 lbs (1.9 to 2.2 tons) unless it is older than 1977. So, a jack rated for 2 1/4 ton (4500 lbs) should work for your application.
Old 09-07-2006, 07:10 PM
Blue Bowtie's Avatar
Registered Offender
Re: Jack Capacity
Are you going to lift the entire car in one shot? Usually, one axle at a time is sufficient. That requires a lot less jack capacity, and a lot less of that tricky balancing act.
Old 09-07-2006, 07:24 PM
silicon212's Avatar
Confoundingly Lucid
Re: Jack Capacity
I've learned that a decent, 100-lb thrust rocket placed at each corner of the car and aimed down and ignited helps to overcome the tricky balancing issue. I just thought I'd pass that along.
Old 09-08-2006, 11:25 AM
Registered Offender
Re: Jack Capacity
Sure, but how do you light them simultaneously?
Old 09-08-2006, 02:35 PM
silicon212's Avatar
Confoundingly Lucid
Re: Jack Capacity
Oh come on now, it doesn't take a rocket scientist to figure .. umm waitaminit .. yes it does. Sorry.
