Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 09-06-2006, 10:52 PM
accr85 accr85 is offline
Question odometer
if the odometer does not show any thing will the miles still add up ????
if i can replace it will it show correct miles?????
Old 09-07-2006, 03:26 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: odometer
i think you may be getting the trip meter confused with the odometer. if the trip does not work the odometer should still work (i had that problem with my camaro). if u choice to by a replacement guage cluster, it be at 0 miles unless u by a used one and it will show the miles of the vehicle it came from. there may be a way to forward it to your trucks actuall mileage but in most cases, just right down what the mileage was then replace the custer if you want to.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 09-07-2006, 09:07 PM
Re: odometer
it is the led display... the electronic one on that has the odometer and trip meter built you hit a button to se one another... it is on the newer gmc models that light up only when the car is on ....this one will not go on at all it
Old 09-07-2006, 11:00 PM
ZL1power69's Avatar
GM S-Series Mod
Re: odometer
o ok. the ecm should still keep track of the mileage even though the display is not showing up. its probably an electical issue somewhere. do all of your guages and lights still function?
Low 11 sec sleeper
My Cardomain
Old 09-08-2006, 11:34 PM
Re: odometer
yes they do i think you are right i am pro going to have it fixed thanx 4 the help
