Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 09-06-2006, 07:58 PM
soaper soaper is offline
front window washer pump not working
i have a 98 transport/montana. always something to do on this vehicle. anyway, my front wipers work fine, however, the pump to spray the washer fluid just stopped working altogether. i need this problem fixed before the snow starts! any suggestions?
Old 10-02-2006, 02:13 PM
kcarlen kcarlen is offline
Re: front window washer pump not working
Did you check all of the hose connections to make sure that it is not spraying somewhere else? Can you hear the pump run when you turn it on?
Old 10-03-2006, 08:12 AM
rubberman rubberman is offline
is the pump making nay noise? if not its probably either locked up(worn out) or i seen one that rusted up. That should be an easy fix tho
2000 Grand Prix GT w/ gold package.
K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe
2004 Chevy Trailblazer EXT
Keep on Keeping on...
Old 10-07-2006, 08:54 PM
no the pump does not make any sound when the switch is engaged. i'm looking at replacing it.
