Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-06-2006, 07:46 PM
93BONNESSEI 93BONNESSEI is offline
1993 Ssei Sputtering When Speeding Up
my 1993 bonneville ssei w/supercharger has started to sputter or buck when speeding up. it only does it when to boost hits above "0". I had the supercharger replaced and it still does it. any ideas???
Old 09-07-2006, 04:03 AM
DrJay DrJay is offline
Re: 1993 Ssei Sputtering When Speeding Up
Could have saved a buck on the SC, very unlikely it was playing a part. Look at your fuel pressure, certainly have the classic signs. They're also known for failed or weakened coils, which will cause a stumble. Fuel is a good start though.
Old 09-20-2006, 09:42 PM
MONTNUT MONTNUT is offline
My 94 SSEI does the same thing. My mechanic told me it is a magnet that the camshaft sensor reads. It is mounted on the camshaft gear and it is a little involved to replace a $1.75 magnet. Several hundred dollars.
Old 09-25-2006, 11:51 AM
SuperchargedSSEi's Avatar
SuperchargedSSEi SuperchargedSSEi is offline
I am about to buy a 93 SSEi myself and it does this same thing but only when the pedal is put to the floor,up to that it dips along just fine ??
Have you figured out your problem yet ??
My first thought also was the coil pack as I had a similar problem a while back with a 84 century 3.8 T-type and it had a bad / weak coil pack.
