Old 09-06-2006, 07:31 PM
97chevy1500 97chevy1500 is offline
97 chevy wont start!!!
i have a 97 chevy 1500 2wd 4.3 v-6. i just put in a used motor and it will turn over but wont start. i have checked all conetions . i have spark at plugs,gas at the fuel rail. im stumped . any help? thanks
Old 09-08-2006, 11:14 AM
Rs051802 Rs051802 is offline
Re: 97 chevy wont start!!!
Are you 180 out on your timing? Check to make sure the distributor is installed as it was removed. Are you getting spark and fire? Write us back and let us know what you have and have not checked.
Old 09-08-2006, 08:24 PM
i have spark at plugs. i did not take the dist. out. so i dont think its out of time but i will check. someone told me that i might need to switch the intake from the 99 blaser to the old 97 one? is there any diference in them ? all the plugs went together fine. thanks
Old 09-09-2006, 03:18 AM
airdale94 airdale94 is offline
You might need to use your old injectors to be compatible with your computer.
Old 09-09-2006, 03:25 PM
it will start for a second if i spray carb cleaner in it. how do i chang the injectors? do i chang the hole manifold? thanks
Old 09-10-2006, 03:00 PM
i changed the injectors. it will run but rough at idol. runs smooth at 1200 rpm and up. any help with this?
Old 09-13-2006, 11:43 AM
Sorry I diddn't get back to you , I forgot to bookmark your thread. I see you have another one going now anyway. I would check the fuel filter first, then basic tune-up stuff, plugs, dist. cap & rotor, spark plug wires. Your injectors might need a good cleaning. If you haven't ever done it and there is some miles on them I would take it to a shop.
Old 09-16-2006, 02:39 PM
i had the injectors cleaned . still runs like crap at 700 rpm. any other ideas.
Old 09-21-2006, 08:32 PM
this thing runs bad. it sounds like it hiting on 2 cyl at once sometimes. has no power sounds like it backfires in the catilitc converter sometimes. any one want a cheap truck?
Old 09-22-2006, 08:49 PM
What did they say at the shop, when you had your injectors cleaned? I'm trying to chase down a idle problem in my 98 C1500 4.3l M/T. Idles high after warm when driving until I come to a stop, then after about 10 secs. it drops down.
Old 09-23-2006, 06:40 AM
Blue Bowtie's Avatar
Registered Offender
Your problem is likely a dirty IAC stepper motor. Remove it, disassemble it, clean it, and lubricate the pintle shaft before assembly.
Old 09-23-2006, 06:44 AM
Registered Offender
If you connected a newer style (peak/hold) injector pod to an older (saturated injector) PCM, there is a remote possibility of damage to the injector drivers. There is also a possibiliy that your plugs were fuel fouled in the process. I'd pull the plugs and look for a rich condition.
Old 09-26-2006, 12:59 AM
texasboy05's Avatar
texasboy05 texasboy05 is offline
if u get it to start run some sea foam through it n it mght take out the mis and stop backfiring
