1998 S10 Problems
I am writing this for my husband as he is out working on Blazer--bear with me. Blazer won't start. It has spark and is getting gas. Any suggestions? Thanks!
Re: 1998 S10 Problems
Check cold start fuel pressure. Check engine running fuel pressure. Check engine running on the road fuel pressure. Then shut it off and watch for fast leak down. Pinch off at rubber part or block off return line and check full pressure. Later V6 and V8 gm engines should have 60-66 fuel pressure. Cold start should be 64-65 lbs of pressure. If you do not have full fuel pressure on a cold start the injectors will not squirt fuel. Do not leave home without it. Engine running should be 60-66 lbs pressure depending on engine load. Full pressure with return pinched off should be 75-85 or more. And if it has a fast leak down after shut off you have a leak. Post back fuel pressure readings.
Is it cranking over OK - starter turns the engine but no start?
If yes check the fuses in the box underhood - eng and 2 ecm ones. As MT said check fuel pressure. If OK on to next and key on engine off is 60 psi min for Blazers and after 2 sec pump quits and should hold pressure close to that. Has spark but won't start - put a new cap and rotor on and test again - cap can be bad internally so a quick test and yes, it happens. Crank sensor can be bad and that keys coil to fire on correct timing ($60 part). Post back. Next is ign module at $80. |
Thanks. I am going to print both of your responses and bring them out to him. Will give you an update! Keep all suggestions coming.
I have tried all your suggestions. Nothing! UGH!
Forgot to add. The vehicle started just fine; moved it to the backyard; washed it; washed the engine also--then it wouldn't start. ????? This was on Monday.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super Tuner,Viper '98 Pontiac Grand Prix GT, 3.8 '88 K1500 Cheyenne, 5.0, stock, bought new '86 Nissan 720 Trash Truck '69 C/10 step side, 307, all original, second owner, in process of restore. The person who says it cannot be done should not interrurt the person doing it. Share your knowledge. It is a way to achieve immortality. Allen- Paintman Wrenchtwister Broompusher |
1998 BLAZER LS Vin-W 4Dr 2wd 2004 Cavalier LS 4Dr 2.2 Ecotec "Good Part's ain't Cheap--Cheap Parts ain't Good" |
Hey Dino55-just sprayed it with the hose.
I think you have a drowned engine. Did you spray it with engine hot or cold? If sprayed hot youy may have cracked cap and rotor. First thing would be to pull dist cap and check for water in it. If so dry it out and look for cracks. If no cracks put cap back on and try it. You may need to give the hole thing some dry out time to. Good Luck Mt
Funny? I do that routinely. I never have problems with my vehicles washing the engine and bay.
![]() ![]() ![]() ![]() ![]() Then again, I routinely have trouble with other people's vehciles after washing the engines. I use it as a diagnositc aid to find weak ignition components. Works great. I hate working on filthy engines. ![]() ![]() I'm thinking that you, too, found a weak/poorly sealed ignition component(s). |
Could be anything under there.
When you wash an engine you cover everything electrical with plastic grocery bags. He has moisture in there somewhere and god knows what has failed.
1995 Factory Blazer Service Manual for sale, PM if interested. |
Been washing this engine since I got it. This vehicle looks brand new (other than the 260,000 miles). Distributor ok--. Thanks for all your suggestions.
