Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 09-06-2006, 02:18 PM
JobeSmith JobeSmith is offline
3rd cylinder misfire
Hi, i have a cylinder misfire problem. I plugged my scanner in and checked the DTC, twice came up as the third cylinder kept misfiring. I have a spark plug checker that lights up when current runs through it. I have spark from the coil pack to the wire boot, but from there i cant check if i have spark from the wire, to the plug. How do I know if i have a spark issue? Or a injectore issue? At about 3000 rpm the cars rpm gauge dips down a little, like it has trouble accelerating at that point.
Old 09-06-2006, 04:25 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 3rd cylinder misfire
Sounds like you hav spark.
What engine size and year?
Most misfires are caused by injectors, but not all.
They do need cleaning from time to time,
if you dont use injector cleaners regularly.
The V6s an known to hav trouble with the injector wires on and around the intake, possible form heat. The cover on the wires cracks and shorts out..
The 4cyl could very well hav the same troubles.
1999 Grand Am SS 3.4 OHV
Old 09-06-2006, 05:17 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Two things, get a noid light and see if the injector is firing at the proper time. If it is the light will light each time. If not you should see a pause or no light. This will tell you if you have a wiring issue. Secondly, you can pull the injector from another cylinder and place it in one of the non-misfiring cylinders. If the misfire changes the injector is the issue.
Old 09-07-2006, 08:39 AM
A noid light is a good investment!
It works easily on the 4cyl's .
Though on the v6 you cant get to all the injectors without removing the upper intake. Best to do it at the injector harness on these(v6s).
Old 09-07-2006, 10:26 AM
3.1L
im going to take out the plug firt, then try the noid light, and possibly a pressure tester to see if its firing at 60psi, maybe just the one is clogged. All the injectors were just cleaned though, and my plugs were all just changed less than 20,000 miles, which is why im annoyed with this
Old 09-07-2006, 11:43 AM
Pontiac Guy
But did you change the wires too? Wires are one of the most common causes of misfires and one of the most overlooked maintenance items!
Old 09-07-2006, 12:22 PM
My SE has had the wires changed twice because of faulty wiring.
Old 09-07-2006, 01:22 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
And a bad wire could idle fine, but once cylinder pressures raise, the spark may be going somewhere else besides the plug..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 06-03-2007, 10:03 PM
mrelmo mrelmo is offline
how do you use a noid light on a 6cyl without removing the plenum and does anyone sell just a plenum gasket without getting the whole upper gasket set thanks
Old 06-03-2007, 10:30 PM
mrelmo,
please look at the dates before posting.
We dont like to bring up threads older then 2-3 months.
AS out-lined in the Community Participation Guidelines, which is at the bottom of every page.
But to answer your questions,
follow the injector wires over to the harness connector and test from there.
I dont know for sure If they sell just the UI gasket,
but I'm sure they do at some part stores.
If you need any more assistance please post your own thread.
this is closed......
Closed Thread
