Old 09-06-2006, 12:36 PM
gracie01 gracie01 is offline
Send a message via Yahoo to gracie01
What's is going on with my car???
I drive a 93 chevy cavalier z24. It has over 150,000 miles on it. I got a tune up last week. The next day after my tune up my car started just fine but when I put it in reverse my car died. Why did it do this?? I took it back to the guy and it did nothing so he said nothing is wrong with my car. Do I just need to let my car sit idle for a few mintues before I back up??? Also, I have a rough idle when I sit at a stop light/sign etc. Is that normal for older cars?? And after I back up and get moving when I try to acclerate it seems like it takes awhile before it will kick in and go. But sometimes it will just kick in and go. Does that mean I have a problem with my transmission? Every time I fill up with gas I put Chemtool into my gas tank and that helps with that problem. Or is there something wrong with the fuel injection?? Please give me any input. Thanks
Old 09-06-2006, 12:43 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Re: What's is going on with my car???
Your car's idle is weird in how it works. If the battery is disconnected for a bit it has to re-learn idle. There's a procedure, but long story short, stick it in your driveway, pull the e-brake, and leave it in reverse for 5 minutes. Should fix the problem.
Oh yeah, and don't put additives in your gas... just trust me. Run premium if you need to clean it.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 09-06-2006, 12:49 PM
my99cavy's Avatar
my99cavy my99cavy is offline
Send a message via AIM to my99cavy Send a message via MSN to my99cavy
And when you do this make sure you sit in the car just to be on the safe side in case your e-brake fails for some reason.
Why not use additives?? I put fuel injector cleaner in my car because it was bogging and shooting smoke and that stuff cleared it all up. After I used it there was no smoke and no more bogging.
Old 09-06-2006, 01:50 PM
joeuser742 joeuser742 is offline
I used to own a 93 cavalier z-24. There are many things that you can check. You could check to make sure that they changed the wires and make sure that they are plugged in all the way. I read that the Bosch plugs don't work well in certain cars. They could have changed 5 of the 6 plugs. Change your air filter, fuel filter. Check the idle speed control, fuel injectors(if the car is running rough all the time). If the car ran rough when it was damp out, then it could be the coil packs. The last thing I could think of is there could be a vacuum leak.
1998 Blazer 4WD 4.3L 118,000miles 4dr
Repairs
--rear main seal, u/l ball joints, pitman/idler arms, i/o tie rod ends, control arm bushings, motor/trans mounts, oil relocation lines, door pin bushings, water pump, ring/pinion.
--Bad ABS ground, loose connection blower motor, repaired pulse board.
Mods/upgrades
-Throttle plate mod.
1999 Ford Windstar SE 3.8L 160,000miles
Repairs
--P171/P174 procedure, loaded control arms, tie rod ends, shocks, struts, springs.
Old 09-06-2006, 03:01 PM
JStumpalump150's Avatar
JStumpalump150 JStumpalump150 is offline
i swear dealerships fuck with your car when you take it to them cuz they want you to come back and pay more money.....it would be one thing if something happened that was under warrentee but it never is, and it always happens right after they work on it
2002 Nissan Sentra SE-R Spec V w/6 Speed Manual
Old 09-06-2006, 05:29 PM
my99cavy's Avatar
It's a giant conspericay (sp?)
Old 09-06-2006, 08:27 PM
Lances133's Avatar
Lances133 Lances133 is offline
Send a message via AIM to Lances133
You are "blazed" - Conspiracy*
Old 09-06-2006, 08:38 PM
my99cavy's Avatar
haha I told you so. that is also why I put (sp?) next to it.
Old 09-06-2006, 09:06 PM
alblogg's Avatar
alblogg alblogg is offline
Nothing wrong with using additives.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 09-09-2006, 11:50 AM
Nothing good, either. And several can cause all kinds of problems with fouling up your plugs.
Meh, like I always say, do what ya want. I'm just pre-emptively reserving my right to an "I-told-you-so."
