Go Back   Automotive Forums Car Chat > Chrysler > 300M
Old 09-06-2006, 10:42 AM
bigdawg70 bigdawg70 is offline
blown fuses
My girlfreinds car jus blew the #19 fuse in her 2000 300m it is for the radio power locks power trunk i have cchecked almost everthing im looking for the body control module does anyone know where it is located? Has any1 else had this problem
Old 09-06-2006, 11:44 AM
tinmanwpk tinmanwpk is offline
Re: blown fuses
I do not have access to my manual right now, but if I were to make a guess it may be under the hood. Look on the driver side and there is a rectangular box (probably labeled "fuses", maybe not). It is black with yellow lettering, about 12" long by 3". Your fuse may be under there. My manual is at home and I am at work, so I apologize if this is incorrect info.
The other possibility is it is in the fuse panel which is on the drivers SIDE of the dashboard when the driver door is open. Once the panel is open, look carefully on the inside of the panel door and the fuse numbers should be marked on that panel.
TinMan
99 M Cypress Green, performance rear sway bar, Brembo rotors w/CT3 pads, tint, Sirius, K&N intake, debadged, many other mods.
