Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 09-06-2006, 08:24 AM
aquaman0001 aquaman0001 is offline
Passat instrument cluster
Hello,
VW told me they "Think" I need a new instrument cluster.
Does anyoen know where I could get a used one or one at cost?
I have a 2000 Passat 1.8T.
Thanks
Old 09-25-2006, 06:22 PM
newin96 newin96 is offline
Re: Passat instrument cluster
What's the reason for the instrument cluster?
Is it "The ABS, brake and oil lights come on sporadically and the tachometer stops working"?
If so it's the ABS module. Get it rebuildt (easy process to remove to send out ~1hr). You can even drive your passat (just no ABS) while your waiting fo the rebuildt unit.
Old 09-26-2006, 07:30 AM
Hello,
VW screwed up as usual. I went to a local mechanic. I need a new ATM. Had water on the rear passenger floor.Why does VW not put 2+2 together? The mechanic cleaned and dried the module but it doesnt shift well. I am hoping to find a good used module.
A
