Old 09-05-2006, 11:58 PM
ChevyGuy07 ChevyGuy07 is offline
Exclamation 90 Camaro wont start
I have a 1990 Camaro RS and most of the time i have trouble starting it. I have replaced the starter many times and the problem is still there. Sometimes if i bang on the starter with a hammer and have someone turn the key at the same time it will start. I have checked the battery and it is good. I have replaced the negative cable and still the same problem. What could it be? PLEASE HELP!
Old 09-06-2006, 10:34 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 90 Camaro wont start
A starter [rbolem that requires it to banged on all the time would point to excessive heat. Are you sure don't have a restticted exhaust (power fall off when warm?).
Also, it could just be coiincidence that each time you 'bang' on it, you're correcting a poor connection
Old 09-07-2006, 04:09 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
ever tried shorting across the terminal to see if its a key problem instead of a starter problem? if it starts right up it might be like wright said a bad connection OR a ignition problem..
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
