Old 09-05-2006, 10:37 PM
hypnoman55's Avatar
hypnoman55 hypnoman55 is offline
1990 camaro rs probelems
] i was out one day driving has u do , then the car shut down completly. luckly i was only down the road . got the car home checked the battery ok. put the key in nothing. tokk the starter out cheched it ,fine! so checked all the fuses ,good . thought maybe vat syatem ! took the steering wheel off checked the i-switch wires broken ,so changed the switch and key put it back together nothing help!!!!!!!!!!!!!!!!!!!!!!!! anyone
edited by wrightz28 - font removed as it destracted me, trying to find the original problem here.
Old 09-05-2006, 11:01 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: 1990 camaro rs probelems
sounds like it could possibly be a fuel pump on its way out
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 09-05-2006, 11:08 PM
stepho stepho is offline
Send a message via AIM to stepho Send a message via Yahoo to stepho
if you turn the key to the on position you should be able to hear the fuel pump. Turn your car on, get out and put your head by the gas tank. If you don't hear like a buzzing, kick the gas tank a few times and see if it will come on. If still nothing you are going to have to pull the tank and change the fuel pump.
Originally Posted by sportlinetta
lol, u guys are dummmmmmmmmmmmb im 14 n i know more. i gotta 88 camaro.
would that mean get a new cylinder or plug???
Old 09-06-2006, 02:56 PM
hypnoman55's Avatar
Cool Re: 1990 camaro rs probelems
turn the key on nothing on the switch but the front lamps work and lighterand the radio , thanks !!!!!!!!
Old 09-06-2006, 03:09 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
If there is no indication of the fuel pump coming on, check and make sure the t/p fuse by the battery on fender wall is good. From there I'd check the relay on the firewall by the brake booster.
Old 09-06-2006, 04:53 PM
hypnoman55's Avatar
checked fuse ok !
Old 09-06-2006, 11:20 PM
Blue Bowtie's Avatar
Registered Offender
Check the relay, or jumper 12V power to the 'G' terminal on the ALDL to manually operate the pump. Some pumps are noisy, others are very quiet (especially the roller vane pumps),so listen carefully.
Remember that the pump will only run for a two-second prime cycle, then remain off until either the engine is cranked (distributor reference pulses) or the ignition is powered down for at least 20 seconds.
Old 09-07-2006, 06:55 AM
hypnoman55's Avatar
thanks! I'll try that today !later
Old 09-07-2006, 01:54 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
how did your car shut off? did it shudder a lot before it shut off? or did it smoothly cut off..
if it shudderd-> fuel problem
if it was smooth->electric (spark) problem..
most likely, anyways..
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 09-07-2006, 07:32 PM
hypnoman55's Avatar
just shut-off on the road !!!
Old 09-07-2006, 09:20 PM
TEXAS-HOTROD TEXAS-HOTROD is offline
Pull the coil wire from the distributor and install a good spark plug into the boot. Lay the plug on something metal, crank it over and check for spark. If it has spark, install the coil wire, remove a spark plug wire and do the same. If it doesn't have fire at the plug wire, it's the cap/rotor. If it does, install the plug wire.
Remove a main vacuum line (PCV valve works good) and shoot some carb cleaner down the tube. Crank it over and see if it will try to start, or if it will start and die. If it does start/tries, then most likely it's the fuel pump. If the fuel pump went out, it's caused by a plugged fuel filter.
You don't want to guess at what's wrong and throw parts at it. That'll just cost you extra.
Check for fire and post back.
Old 09-07-2006, 09:30 PM
hypnoman55's Avatar
the car doesn't crank at all . nothing with the key!!!!!!!!
Old 09-07-2006, 10:52 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Are you saying the starter isn't turning the engine over? If so, that's not fuel pump related..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 09-08-2006, 11:21 AM
Registered Offender
Fusible link, anyone? VATS would not have shut it off, but would prevent restart depending upon the failure mode.
Old 09-08-2006, 12:16 PM
First thing i'd do would be to test for battery voltage at the starter, then test for battery voltage on the wire coming from the ign. switch while the key was turned to start..
