Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-05-2006, 04:32 PM
LeakSmoke LeakSmoke is offline
Send a message via AIM to LeakSmoke
Possible power steering/hose problems? I dont know :|
The other night something blew on my car. It was a yellowish fluid an doubt its coolant. But the problem is my steering wheel is stiff and wont budge for crap. I think (but dont know for sure) its a hose for the power steering or something of that sort. But i dont know a whole lot when it comes to cars. Anyone know any possibilities on what the matter might be? Some of the fluid was starting to leak through the front head lights. Now im out of commission :| Any help would be apretiated.
Old 09-05-2006, 06:06 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Possible power steering/hose problems? I dont know :|
Open the power steering resivior cap and see if there's any fluid in there. If not, try adding some and see where it leaks from. Then you can find out where its leaking from.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-05-2006, 08:44 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
What kind of car, year, and motor also.
95 Talon TSI AWD
97 Eclipse GST
Old 09-06-2006, 03:24 PM
little update. it was low on power steering fluid. But it doesnt leak from anywhere. I drove around the block and found out my radiator hose had a hole an was squirting out fluid. I changed the hose and added more coolant. But the problem is still there. Now its making noises. I dont know where to sart :| Ah.. and its a 99 gs 420a 5 spd And the steering wheel is still stiff as a board.
Old 09-06-2006, 04:02 PM
Bodack Bodack is offline
Send a message via AIM to Bodack
"Power steering fluid" is usually red because it's usually just automatic transmission fluid. That's what the Haynes manual calls for anyways. Follow the hoses to/from the pump to check for leaks and check the connections on the pump itself because this is obviously a power steering problem. Unless you mean the wheel just won't turn at all. Will it turn, but with difficulty? Or will it just not turn at all?
1993 Honda CBR900RR
1990 Talon TSi AWD - Sold
1990 Laser RS turbo - Sold
1993 Eclipse GS - Sold
Old 09-06-2006, 04:10 PM
It wasnt power steering fluid but coolant that was everywhere. But the hose for that is fixed. I filled the power steering and the hoses dont leak or anything. and they are all connected. i can turn the wheel but i have to put some muscle into it. When i pick up speed i can move it slightly better. But on turns i have to pull the wheel pretty hard to make it turn.
Old 09-06-2006, 05:03 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
did the belt brake....lol stupid question but still
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 09-06-2006, 05:10 PM
fan or timing? I have a new timing belt. And the fan belt is fine.
Old 09-06-2006, 05:14 PM
He means the power steering pump belt. Very good question actually... If it's there then I'd say the pump failed maybe? I don't know if a power steering pump can fail or not, but I could have. I took mine off and I've gotten used to it.
1993 Honda CBR900RR
Old 09-06-2006, 06:08 PM
All belts are fine. I doubt it has to do with the power steering now.. and just with the steering. no luck yet :| Thanks for all the responses.
