Aftermarket Wheel bearing hub assembly
Well I got screw again, 1st time I decided to install champion plugs the engine ran great for abought a year and the engine started missing thinking no way It could have a plug problem considering I replaced the suckers not that long ago, That cost me over $400 to correct at the dealer. It seems I got screwed again 12 to 14 monthts ago I replaced the front Wheel bearing hub assembly with an aftermarket unit, well oh well it is making noise again I called the retailer where I bought it and they said tough that unit only had a 3 month warranty screwed again. Man oh man I am either having bad luck with aftermarket crap or our Intrepids only work with OEM stuff.
Re: Aftermarket Wheel bearing hub assembly
![]() The three top hubs based on my experiences is AC Delco, Timken and BCA-Federal Mogul. Any thing else like white box or made in China versions are garbage.
Wagner supposedly also makes a wheel bearing for our cars, but ive never seen one for sale in an auto parts store, i may be buying one from a member of ClubGP fairly soon, so ill let you know how it works out.
He supposedly works for a dealership and they ordered it directly from Federal-Mogul, who owns Wagner. |
2000 : OLDSMOBILE : INTRIGUE : 3.5L 214 cubic inch V6 FI (H) : Brake/Wheel Hub : Axle Bearing and Hub Assembly BCA Part # 512150 Rear Wheel; Hub Assembly {Rear Wheel Has ABS with Integral Sensor Bolt Quantity=5 Flange Dia=5.93" Bolt Circle Dia=4.53" Bolt Size=M12X1.5" Wheel Pilot Dia=2.76" Brake Pilot Dia=2.78" Flange Offset=2.56" Hub Pilot Dia=2.83" Flange Shape=RECTANGULAR} $96.99 BCA Part # 513121 Front Wheel; Hub Assembly {Front/Rear Wheel Has ABS with Integral Sensor Bolt Quantity=5 Flange Dia=5.728" Bolt Circle Dia=4.527 Bolt Size=M12X1.5 Wheel Pilot Dia=2.759" Brake Pilot Dia=2.759 Flange Offset=2.736 Hub Pilot Dia=3.598 Splines=33 Flange Shape=MODIFIED TRIANGL} $135.79 ACDELCO Part # 2017 HUB KIT,FRT WHL {#07470017} $207.79 ACDELCO Part # R2011 HUB, RR WHL(W/WHL SPD SEN) {#7470611} **Non-stock item--shipping delayed up to 12 business days** $222.79 $0.00 $222.79 |
I believe he said they were close too, if not more than 200 bucks a pop brand new. Which is a little overpriced IMO. I ended up just buying a used OEM unit from Ed Morad over at ClubGp for the same price, 60 bucks, plus a 90-day warranty, which isnt too bad as far as im concerned. |
My source for OEM GM/AC Delco parts is based in Flint, MI and it looks like $150 for brand new AC Delco abs hubs is quite reasonable. ![]()
