Old 09-05-2006, 04:17 PM
slow95z slow95z is offline
Send a message via AIM to slow95z
LT1 Knock Sensor
I have a 1995 lt1 camaro with crane gold 1.6 roller rockers and i would like to know if they would set off my knock sensor causing timing alterations. kinda new to the lt1 knock information world any help would be appreciated, thanks. and also i have ordered a pro 5.0 shifter, i was wandering if anyone reading this had experience with it, likes or dislikes, thanks
Old 09-05-2006, 04:25 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: LT1 Knock Sensor
Not the most versed in LT1's, you'll get a much better chime no doubt soon.
But, a knock sensor in general is only focusing on the engine bottom end (detonation).
Also, roller rockers are quite a bit quieter than solid, and should be what came in the motor origianlly.
don't see any issue from this point
Old 09-05-2006, 04:33 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
I can't see that hurting but if you do want to upgrade to an LT4 Knock Module it's easy to do and pretty cheap
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 09-05-2006, 04:36 PM
one of my rocker arms is ticking more than it should, so i'm assuming that it needs to be adjusted. probably backed off the stud,but why i asked about it is that the car feels like it's losing power from the time the noise started to become apparent, the sound was only minute at first, but gradually increased and ever since the noises started the car feels like it's losing power.
Old 09-05-2006, 04:37 PM
sorry for not including this in the prior post, but this is only a recent thing. i'm not driving the car with a loose rocker arm or anything like that.
Old 09-05-2006, 04:39 PM
wrightz28's Avatar
Well, you're in better hands now with Cuda
Old 09-05-2006, 05:01 PM
are your crane rockers self adjusting? if so they are probably installed/adjusted the same way as the gm roller rockers. you tighten the nut on the rocker untill the rocker has zero lash (doesnt move back n forth) then you turn the nut 1/2 - 1 full turn, put in the set screw and you're done. The power loss could be from a valve not opening/closing right.
Old 09-05-2006, 05:36 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Get yourself a LT4 Knock module. It is only like 40 bucks on ebay and is what LT1 with roller rockers were meant to have.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
