Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-05-2006, 03:52 PM
amboru amboru is offline
88 Sub check engine light
My 88 sub check engine light comes on after it runs on the highway for 1/2 hour or so. I shut the truck off and it clears. I drive 1/2 hour to work some interstate and some city. The light never comes on. How can I check the codes?
Thanks
Old 09-05-2006, 07:54 PM
Supergumby's Avatar
Supergumby Supergumby is offline
Re: 88 Sub check engine light
Probably a code 32, EGR system.
Old 09-06-2006, 11:55 AM
Thanks I will do a little homework and check with Autozone to see if they can test or verify the code error.
Old 09-06-2006, 03:19 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: 88 Sub check engine light
AZ cannot scan a pre 95 vehicle.
Old 09-06-2006, 03:39 PM
2000CAYukon 2000CAYukon is offline
www.troublecodes.net/GM
//2000CAYukon
Old 09-06-2006, 04:53 PM
Blue Bowtie's Avatar
Registered Offender
You’ll need to acquire a GM ECM Diagnostic Trouble Code Retrieval Tool. (Most of us just call them “paper clips, but GM has to have some fancy name for them to charge more.) Cut the clip in half so that one end of it is still bent in a “U” shape. If you’re careful, you can make TWO error code retrieval tools from one paper clip.
With the engine and ignition turned off, locate the ALDL connector under the dash, just to the right of the steering wheel in the driver's foot well area on some models, and on the left on others, depending on the make and year. There may be a small rectangular cover over the access hole in the lower dash trim.
Insert a jumper tool or the aforementioned paper clip into the 'A' and 'B' terminals on the ALDL connector:
WITHOUT STARTING the engine, turn the ignition to the "RUN" position. Watch the Malfunction Indicator Lamp (MIL) - it will begin to flash. This is also commonly called the “Check Engine”, “CEL”, "Service Engine Soon" or "SES" lamp. The first code will flash three times, and will usually be a code '12'. This is encoded by one flash of the lamp, a brief pause, then two successive flashes of the lamp. Each code will repeat three times, so you should see a "Code 12" flash three times. Any other error codes will follow in numerical order, and each code should flash three times. After all codes have been displayed three times, the "Code 12" will again flash three times, then all other codes will follow as described earlier. This cycle will continue until the jumper is removed or the ignition is turned off.
After you have made a note of all error codes, turn off the ignition and remove the jumper immediately. If you forget to remove the jumper and attempt to start the engine with it in place, you could damage the ECM. For this reason you should remove it immediately.
Once you have a note of all error codes, check this file for the decoding:
GM Error Codes.pdf.
You'll need Adobe Acrobat Reader to open/print the file.
