Old 09-05-2006, 03:49 PM
manwiththeplan88's Avatar
manwiththeplan88 manwiththeplan88 is offline
Spark plug wire problem
I finished my tune-up today, fuel filter,cap,rotor,radiator cap,oil change,pcv valve,spark plugs, radiator flush,tranny flush and refill w/ new filter, and other small things. Everything went really smooth until I got to the last spark plug. On plug #6(the one on the passenger side closest to the back of the engine) I was pulling the boot off the old spark plug and the wire ripped right off the boot, now I need a new plug wire. Can I drive the vehicle for maybe 20 mile round trip without that wire installed until I get a new one?
1997 Blazer LS 4dr
180,000 miles
Old 09-05-2006, 04:38 PM
RJ MALIBU's Avatar
RJ MALIBU RJ MALIBU is offline
Re: Spark plug wire problem
Why Round trip? cant you put the wire on in the parking lot? i think youll be fine with only 5 cyl
1997 Blazer w/99+front end with clear Euro Projector Headlights and parkinglights and cai 2 -12'' Dual subs 600w RMS 600 watt kenwood amp Sony head unit
2003 malibu-bone stock(wife's car)
Old 09-05-2006, 04:40 PM
RJ MALIBU's Avatar
Should be O.K to run 5 cyl.just dont leave broken wire on to arc everywhere
Old 09-05-2006, 05:52 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Comon man, you know better than to say something like that. Do you know about a thing call hydrolock?
manwiththeplan88,
Strip the wire back a bit to expose the inner conductive core and push the wire back into the boot so that it makes a connection and give it a good taping just to get you their.
Running with one cylinder not firing will have you introducing gas into your oil and potential hydrolocking that cylinder.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-06-2006, 07:17 AM
billibong's Avatar
billibong billibong is offline
I have to agree with BLT on this one, you could cause a lot more problems than you have now. Can you get someone to take you up to the parts store?
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 09-06-2006, 09:00 AM
BlazerLT's Avatar
AF -Advisor
I have had wires go bad like that and all you can do is press the broken part back into where it ripped out of and you will get a good enough connection to get the plug firing.
This is why you always grab the wire by the boot when removing the wire from the plug. Never just pull on the wire.
Old 09-06-2006, 10:07 PM
Ok i just bought a new set of wires. I learned my lesson the hard way, I wont rush a tune-up ever again. Thanks for the help guys.
1997 Blazer LS 4dr
180,000 miles
Old 09-06-2006, 11:56 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Just to add to this, you will never hydro lock the engine if you have a missing cylinder - have seen it many, of many times, you won't hydro lock it. What you will do is have poor acceleration, undo stress on bearings, and you will eventually damage your cat. converter because of excess fuel being burned in the converter. Your computer will always be trying to trim the excess fuel as read from the 02 in the exhaust. You will eventually get a missfire code, and possibly a 02 sensor malfuncution code.
Basically if its not an extreme emergency, then its not a good idea to do this.
