Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-05-2006, 03:11 PM
airFS airFS is offline
Question Clutch install
I've been trying to put off buying a clutch for a little while now and it's beginning to slip very bad. I have everything picked out but I havent bought it yet. What I wanted to know is how hard it is to install a new clutch/flyweel and how long it would take. Or should I just take it to a shop and let them install it. If I decide to install it are there any directions on any sites that take you through it step by step or am I on my own??
96' Talon tsi AWD
Mods: greddy upper and lower intercooler pipes _ greddy type rs bov _ K&N intake _ 3" turbo back exhaust _ ngk spark plugs & wires _ garrett T-28 turbo _ greddy oil catch tank
Old 09-05-2006, 06:05 PM
L-Spec's Avatar
L-Spec L-Spec is offline
Send a message via MSN to L-Spec
Re: Clutch install
AWD eh... FWD it would be a snap, but for AWD you'd have to take out the rear end. If you're dedicated, it could take most of the day. If you're no familiar, I don't suggest it because of all the driveshaft BS you're going to have to deal with. I paid $150 for a clutch install on my rotary, so it wasn't that much of a loss at all. We worked on a FWD DSM in the shop and it was pretty straight forward.
1992 Ẽfini RX-7 FD3S
Old 09-05-2006, 07:09 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Clutch install
Only $150? Damn, that's cheap as hell. Every shop around here wants to charge at least $250 just to drop the tranny. Then the labor chargers and any other parts they need and such. Damn, do mine, yeah?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-05-2006, 08:17 PM
boyertownMidnight's Avatar
boyertownMidnight boyertownMidnight is offline
Send a message via ICQ to boyertownMidnight Send a message via AIM to boyertownMidnight Send a message via Yahoo to boyertownMidnight
Re: Clutch install
if your from the philly area, ill help you put it in for free ...wheather or not its awd or fwd it takes me like 3 hours to get a clutch in and together so give me a shout if your in the area of berks county, [email protected]
Old 09-05-2006, 10:24 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Clutch install
[quote=L-Spec]AWD eh... FWD it would be a snap, but for AWD you'd have to take out the rear end. QUOTE]
You might be thinking of a different awd setup, on the dsm's the only difference betweeen fwd and awd is that you have to take the transfer case off.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 09-06-2006, 01:45 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: Clutch install
Yeah you just need to drop the tranny out...you dont need to take the whole rear end off....if you are decently technically inclined I would say you could probably do it yourself if you have a way of getting the tranny out without breaking your face when you drop it out...such as and engine hoist or tranny jack....but it is pretty time consuming...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
