Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 09-05-2006, 01:11 PM
Denis Couillard Denis Couillard is offline
Thumbs up 4.3L Sonoma 99 AC/Heater Blend Air Door
I did'nt use heat since many weeks and and blend air door don't seem work because i get cool air only at any position (cold on AC and fresh on heat). I checked for proper liquid level and the hoses at at heater are hot. Can somebody explain me where the blend air door is located? I looked under the dash and behind glove box to find 4 vacuum control but none seem to be the blend air door. Help would be appreciate !
Old 09-19-2006, 08:57 PM
jeremythebruce jeremythebruce is offline
Re: 4.3L Sonoma 99 AC/Heater Blend Air Door
I have the same problem and question in my 98 sonoma. Any response would be greatly appreciated.
Old 10-24-2006, 10:13 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
The hot/cold blend door is operated electrially via a servo motor and is located on the passenger side nearer the transmision hump. For diagnosis, first check the dash switch for worn contacts before tearing apart the dash to get to the servo motor. Good luck!
Oops, old post...hope this closes it.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
