Howling or Humming front end noise
the mighty D strikes again... 2001 5.9L 4wd slt makes a humming or howling noise (sounds like left front). Wheel bearing??? advice appreciated.
If it is a wheel bearing - has anyone had any luck re-packing them? I suspect the ansawer is NO since almost all newer vhehicles used sealed units. |
Re: Howling or Humming front end noise
Also need a bearing, have u priced them.I changed a couple on my cars and they were a hub and bearing assembly which I think durango is the same, dont think you can repaCK
2000 bonn ssei 155000 klm 1997 dodge caravan 92000 klm |
They seem to be available for @ $130 each or so. I haven't dug in depth to see who has the best price yet. Will post when I find out.
Make sure to check the ball joints while your in there....
2007 Certified DaimlerChrysler Service Technician... True blue GM at heart. |
I just had mine done on my 02 Durango yesterday, I was going to do it myself but the hub was stuck on there pretty good. If you live near anywhere that might make the hub rust than expect it to be a PITA.
Most likley you will need a puller also. |
