Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 09-04-2006, 11:36 PM
braindead braindead is offline
Send a message via AIM to braindead Send a message via Yahoo to braindead
who knows about preludes?
the other day i stumbled onto a 99 prelude and picked it up now im trying to learn about the car and possiable mod's that are available but all i seem to be able to find is a million sites selling ricer crap "fart cans, huge wings, body kits, ect.." now im sure there is decent info out there about the h22a but i just cant find it. if anyone can tell me were to find info on better performance gear like intake manifolds, heads, cams, maybe foged rotateing assembily? im not wanting to make the car a race car or anything i got my gas gulping cobra for that but i would like this daily driver of mine to be a low 13sec car
Old 09-05-2006, 10:59 AM
92_prelude_si's Avatar
92_prelude_si 92_prelude_si is offline
Re: who knows about preludes?
What about nitrous? If not, have you tried looking on other forums? H-T has as many people as here. Google h22 mods and your question will be answered.
Old 09-14-2006, 03:46 PM
J-Wat J-Wat is offline
AF -Advisor
Intake (CAI, IM, TB)
Exhaust (Header, Cat, Cat-Back)
Jackson Racing Supercharger (or a turbo w/e)
Build the block (sleve, pistons, valvetrain)
Get a chip and have it tuned (Hondata, Chrome, etc...)
that will give you about as much gain as a prelude can get
Old 09-18-2006, 12:26 PM
davybprelude93's Avatar
davybprelude93 davybprelude93 is offline
Send a message via AIM to davybprelude93
You could go to http://www.gripmotorsports.com/dl~pn...ts_Header.html for some headers, go to http://www.evasivemotorsports.com/me...&Store_Code=EM for an good exhaust. Thats just a couple of sites i know, you can just google for everything else.
Old 09-21-2006, 10:15 PM
KahnBB6 KahnBB6 is offline
What you are looking to do with your car... you should look into building a turbocharged engine. For this, you will need to pull the engine and replace the con rods, piston rings and pistons with forged units as the stock parts will not handle the boost. The crank should be fine.
If your car is a Type SH, you can get away with about 210 wheel HP before you need to custom mount a Base transmission.
Greddy makes a turbo kit for 97-99 models if you don't know where to start on turbos. Most people design their own kits.
Jackson Racing still offers their infamous Prelude supercharger. infamous for high intake temps but if you can get a tuner to give it some engine management, most folks seem to like it for about 260HP. Turbocharging is cheaper. If you live in a SMOG state, this is probably your only legal option.
As for naturally aspirated power... I will get flamed for this but I own a 2000 Type SH myself so whatever.... don't bother. I don't feel it's worth it to modify the car's engine unless you plan to use forced induction. For the performance numbers you want anyway. A track only car is another story.
Type SH cars also have a different suspension up front than a Base Prelude. Other threads should cover the correct spring/shock combination for SH models. Brakes should be left alone except for steel lines and better pads. Only high powered turbo Prelude should even consider a big brake kit. Look into changing the rear sway bar for better handling. Just know what you're doing when you go about it. lift-off oversteer happens in FWDs too.
I am sure I will be flamed for some of my stances on modification, but as a Prelude owner this is what I feel you should know. Be realistic about your performance goals on these cars. If you'd rather not get into a full engine rebuild and turbo system, you can still get very enjoyable performance with a header, intake and whatever ECU tuning you decide to go with. It just won't net you super low ET's.
Hope this helps. It's pretty general. Others cover these topics MUCH better than I can.
Old 09-25-2006, 10:41 PM
AllmotorBB6 AllmotorBB6 is offline
Link Removed by Moderator: No offsite [forum] linking, please read the guidelines.
Old 10-03-2006, 12:19 PM
sara200587's Avatar
sara200587 sara200587 is offline
ok i need help! i am in the process of buying a 92 prelude and someone decided to blow the engine. i was wondering for those that know a lot about preludes. .where should i get a new engine from?
Old 10-03-2006, 12:21 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
i thought the H22 was a good n/a engine
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 10-03-2006, 12:22 PM
BLU CIVIC's Avatar
調整器
how much are you getting the car for or have you already purchased it? if you didn't but it yet, i'd look for another
The name's Adrian
2011 CR-Z - Stock
Old 10-03-2006, 12:41 PM
sara200587's Avatar
well its only gonna cost me 1200 im buyin it off of my uncle, and hes going to install the engine and anything else for free..
Old 10-03-2006, 12:42 PM
sara200587's Avatar
the engine is the only thing wrong with the car, everything else is fine. i got my heart set on this car. my only problem is figuring out where to buy an engine..
Old 10-03-2006, 12:44 PM
go to hmotors.com, you can get a new engine or engine and tranny if you need.
Old 10-03-2006, 12:50 PM
sara200587's Avatar
thanx i really appreciate your help
Old 10-03-2006, 12:53 PM
No problem, there engines are not brand new, but thats because they put 30k miles, because they wear in the engines for you.
Old 10-03-2006, 01:46 PM
sara200587's Avatar
wow, u were right. i saw one that i think would be perfect for my prelude.. ill get my uncle to check it out.. hopefully she'll be runnin in a month.. i cant wait to start working on the body.. ima keep the body kit it has, but i might sell my carbon fiber hood... any suggestions on a price for it?
