Old 09-04-2006, 08:25 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Need Info on Third Gens
Yeah, me, with everything I've done to third gens I STILL don't know enough. Since my money situation got worse, I wanted another Iroc-Z or a GTA. Were there any manual 305s made with 4 wheel disc brakes?
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 09-04-2006, 09:09 PM
Nate355RS's Avatar
Nate355RS Nate355RS is offline
Re: Need Info on Third Gens
There were a few 305 tpi z28s that had 5 speeds and disc brakes, but how many and what years I'm not sure. I know that in '92 the 305 5 speeds ran right with the L98's of the same year, so that would be the one I'd recommend.
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
Old 09-04-2006, 09:13 PM
Dyno247365's Avatar
I really want a 1LE packaged camaro but they must be expensive. I found one on ebay but it has no miles and they want 15k for it.
Old 09-04-2006, 09:15 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
the 5 speed tranny's in the 3rd gens suck, they can't handel any power. 3rd gear likes to go out on them.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 09-04-2006, 09:19 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
there were not many 5 spd 3rd gens made and not many of those had four wheel discs. i think you have better luck finding four wheel discs on auto equiped third gens, and i think a lot of GTA's had them. if u want a 1le, you can't really get into one for less then 10 grand. a better alternative would be a B4C camaro.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 09-04-2006, 09:36 PM
Dyno247365's Avatar
B4C is automatic isn't it?
Why were the T5s so bad?
Old 09-04-2006, 09:40 PM
ZL1power69's Avatar
GM S-Series Mod
no, same option as the 1le; 305TPI/5spd or 350TPI/auto
t5's can only handle a max of 300ft lbs. i was making about that in my iroc and i never had a problem other than i had trouble going into reverse (not all the time, just on occasion)
Low 11 sec sleeper
My Cardomain
Old 09-04-2006, 09:42 PM
Dyno247365's Avatar
Sounds like a good idea. I thought cops had to have the automatic. Were they allowed to use that model?
Old 09-04-2006, 09:46 PM
Dyno247365's Avatar
So wait, the T5 didn't even handle it's stock power?
Old 09-04-2006, 09:49 PM
97cavalier's Avatar
the t5 did not come in a 350 just a 305 because the 350 would tear it appart.
Old 09-04-2006, 09:53 PM
ZL1power69's Avatar
GM S-Series Mod
it could not handle the torque. the 305tpi was making 255 ft lbs in 1991 and 285 ft lbs in 1992. the 350 made 345 ft lbs.
Low 11 sec sleeper
My Cardomain
Old 09-04-2006, 11:19 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
certain models of the t-5 were better than others. If you find one with the notation W/C which stands for world class i think those are the good ones. Its hard to know if a car has it without looking at the actual trans. Any Z28 camaro with have 4 wheel disc as long as it has the J65 prod code option which i think most of the z28's did. 305 or 350 doesnt matter. those were some decent motors...the tpi 305's that is.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 09-05-2006, 01:08 AM
Dyno247365's Avatar
It's the fastest car I've ever driven, good acceleration, quiet rumble and then a serious WOT. I really want a manual. If they're that bad though...sheesh. I really do like how they look too. I saw an Iroc at Riverhead Raceway, doing the spectator drags around the oval.
Old 09-05-2006, 09:37 PM
AFI 05 AFI 05 is offline
Send a message via AIM to AFI 05
look for a g92 rpo.. those had dual cats and 4 wheel disk brakes.. even on the 305 tpis with a manual.. theyre kinda hard to find tho.
1990 IROC-Z 5.7 TPI (1 out of 4,213 IROC's made in 1990) Only mod is magnaflow 3" cat back and K&N filters... im broke.
Old 09-06-2006, 07:01 AM
Dyno247365's Avatar
Which models have the WorldClass T5's? I forgot to ask.
