| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
crashed car coolant is foamy
i hit a pole like a stop sign size. it asnt a stop sign though anyways i smashed the bumper and pushed the rad a bit and the rad suport is bent. i did this on friday and went camping till today (monday) and my coolant light has been on for a few days before. so i checked it when i got back and it was a light green color, so i was just going to throw some water in it till i fix everything and then it was bubbling up with foam not a lot but still kind of foamig. so did something get in there when i crashed or what?
Re: crashed car coolant is foamy
Depending on what car you have, some you can't put any water in the coolant.
Silverado Ext. Cab 4x4 z71 Pioneer 4900mp Orion P6.2 Componet sets front Orion C63 Coax rear DirectedVideo 9" all in one DVD with surround 2007 SATURN OUTLOOK AWD XR with full entertainment package |
i know your not supposed to but i drove maybe 5 min and there was still a\cooolant in there i hava 91 tsi
Neef, where was the bubbling, inside the overflow bottle, or inside the rad. cap? Take a 50/50 mix of green coolant and water and fill up the rad. and overflow bottle and you should be fine. Also check the radiator for leaks, you might have a leak. The coolant light means that you're low on coolant so if you smashed the rad., you need to get that fixed, but always keep it full of coolant or you could seriously damage your motor. Last edited by gthompson97; 09-04-2006 at 11:03 PM. |
well i took the rad cap off to fill it up and it would only bubble when i was adding the water. like a reaction my friend said there might eb oil in there so i was just seeing what u guys think the rad was bent but there is no leaks in it a couple weeks ago my rad cap seal was gone and everything was steaming out so i fixed that and then the light came on nd i know i put the thread in the wrong place i waasnt thinking
Anyways, it was most likely bubbling because you were trapping air when you were pouring in the coolant/water. As long as it's not a constant bubble then you should be okay. Just fill it up with coolant and be on your merry way! |
Add a bottle of redline waterwet
GM FOR LIFE !! NEW 1997 Camaro z28 6 speed illa never going back to import , but killa alway be nice to any DSM he saw ![]() looking for 2002 Trans Am LSX UPGRATE 2010 !! 97 Camaro Z28 95 camaro lt1 1992 Pontiac Firebird v6 auto -sold - Pony 1998 Mustang GT 4.6L Manual. Black 1995 Eagle Talon TSI AWD Turbo manual R.I.P 1994 Mitsubishi Eclipse Manual gray -Sold 1997 Mitsubishi Eclipse RS Auto White - Sold |
ok thanks for the help guys
Yep, usually when you add in water and or coolant, it bubbles just like when you fill up a sink then pull the plug. Thank you for using the correct subforums, describing your problem accurately, and using somewhat good grammar
95 Eclipse GS-T 6 bolt built block - shooting for 450 hp..very doable Currently: A lot, check progression thread - updated 3/27/10 Estimated completion date: Soon lol |
I had my coolant bubble and steam when I was really low on coolant. There was a hole in the tank and it dripped without me knowing. When it got really low, the tank filled up with foam and steamed all crazy. Then the car over heated. Maybe a leak somewhere? Not enough coolant?
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
