96 3.0L serpentine belt problems
Hello, I removed the idle pulley to get the belt off, and now for the life of me I can not get the new belt back on. I am wondering if it has something to do with the tension pully?? I checked the belt lengths and they are the same, acutually the thing the new belt is a tad longer..anywas can someone please help me.
Re: 96 3.0L serpentine belt problems
you don'tt pull the belt by removing the idler pulley , you are supposed to pull on the tensioner pull and this will slacken the belt , the reinstall would be the reverse.
You need to get your hands on a serp belt tensioner tool. This is a 3-foot long, flat bar, with a socket head on one end. Use the skinny 15mm socket on the pulley bolt of the tensioner and rotate clockwise to loosen the belt. Good luck!
"This car may be old, but it will still climb Kirker Pass at 110!" 1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible |
Got it back on!
You can use a 15mm socket and undo the tensioner from behind. Have to do it by feel but really helps get the new belt on. Then you just tighten up the tensioner. Worked for me. Thanks for your replys. |
