Go Back   Automotive Forums Car Chat > Renault > Mégane
Old 09-04-2006, 02:03 PM
kev_da_rev kev_da_rev is offline
speedo probs
can anyone help me with speedo problem ...problem being it doesnt work it now and again jumps up and down and then goes back to zero and stops working for another week or so.im driving an r reg megane if anyone has a solution im a bit wary of going to renault because they charge a fortune.
Old 03-18-2007, 12:43 PM
richard_henry_scho richard_henry_scho is offline
Re: speedo probs
hi there got exactly the same prob with my 97 megane garage are saying i need a new dash at over £400. Did u discover what the problem with it was? any help would be gratefully received cheers
Old 07-06-2007, 03:29 PM
rogue13 rogue13 is offline
Re: speedo probs
open you bonnet and look at the drivers side of the engine bay in the compartment under the window you will see a black box remove the cover you will find wiring that is broken that should sort it
Old 09-21-2007, 02:33 AM
Skakig Skakig is offline
Re: speedo probs
Did this sort it out for you!? I have a new megane, that's doing the same thing!
Cheers!
Old 10-28-2007, 03:01 PM
duffcar duffcar is offline
Re: speedo probs
hi got the same problem speedo sits at correct speed then goes nuts all over the shop
Old 01-23-2010, 10:51 AM
ksknoxie ksknoxie is offline
Re: speedo probs
under the black cover is a whit multy plug corrotion can set in with the connections bye pass the plug that should sort it
