Old 09-04-2006, 01:46 PM
darock8566 darock8566 is offline
97 XJ Power Lock Trouble
Ok this past week my power door locks have been on the fritz, the swithes on the door panel wont lock or unlock the doors. But if u lean on the front passenger handle where the switch is it locks and unlocks the doors. I also have a Autopage remote start for the car and even wen i press it 2 lock and unlock it wont unlock the doors it just disengages the alarm and i have 2 use the key to open the door. If any one has a clue on how to fix it or wat it could b i would really appreciate it Thanks guys.
Old 09-04-2006, 10:43 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: 97 XJ Power Lock Trouble
I posted a reply on something like this earlier.
The locks have a switch in them (double pole double throw like in your house for upstairs..downstairs).
They get out of sync.....due to lubrication of the locks..where one is off when it should be on.
Try lubricating the lock mechanisms...
Or do as I do..cycle them until they sync. Lazy man's way.
ALSO.. the switches go bad.
Old 09-04-2006, 11:42 PM
Po Pilot Po Pilot is offline
Send a message via ICQ to Po Pilot Send a message via AIM to Po Pilot
Check your door wiring. Sounds like corrosion or wear has caused them to part.
Old 09-05-2006, 12:33 PM
hey thanks guys as soon as i took the door panel off clearly saw that the harness was unplugged from the switch so that was it thanks guys i owe u. Took me longer 2 take the panel off then fix it lol again thanks
Old 09-06-2006, 10:28 AM
AlohaBra's Avatar
The question now is why it got disconnected.
I assume it is your left door, make sure your harness in not too tight in the hinge area.
Old 09-06-2006, 11:31 AM
it was the passenger side door, no clue on how it came out but i will def. check near the hinge 2 see if its pulling on it.
