Old 09-04-2006, 10:38 AM
lams lams is offline
Thermostat Question
What could occur if I drive my 94 EX Coupe without thermostat?, now I'm driving in a very hot place.
Old 09-04-2006, 11:11 AM
hany's Avatar
hany hany is offline
Re: Thermostat Question
if you drive in a very hot places . you need no to install the thermostat, because you need no hot engine but you will need to cold the engin.
but make all thing carfully and after finish be sure that the fan is work.
MY ENGLISH IS NOT PERFECT. sorry for that
1992 CIVIC 4DOOR ULTRA BLUE TURBO -SOLD
1996 CIVIC 4DOOR EUROPIAN VTEC LS
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 09-04-2006, 03:34 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Driving without your thermostat could cause your ECU to go into an open loop and you'll lose gas mileage. I think the original cooling system of your car is fine and you should drive with a thermostat even in very hot climates.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 09-15-2006, 08:11 AM
GEESERTEG's Avatar
GEESERTEG GEESERTEG is offline
Well said. Your engine will basically try to compensate for the cooler engine. In turn the engine will run rich which will cause other emmission problems in the long run.
http://www.HondaFactor.com ---- Honda/Acura Enthusiast Community
07 Habanero Red Civ Si -- baby's new baby.
94 Honda CivicEX -- 200,000mi ---SOLD
98 Acura Integra GSR --SSBP-- Tein H-techs/Tokico Blues/AEM SRI/More SOON
02 Fud Expedition 5.4 EB
Old 09-17-2006, 06:42 PM
dangstangs dangstangs is offline
Your engine needs to run at a certain temp and that's what the thermostat is for, running without it will cause your engine to run to cool which will cause sludge build up in the crankcase which in turn will cause blocked oil passages which could lead to engine failure.
Leave the thermostat in a add the right coolant mix (most likly a 50/50 mix) and your engine will run like it should.
Old 10-24-2006, 11:18 AM
01_Celica_GT's Avatar
01_Celica_GT 01_Celica_GT is offline
Alright guys, since were on a thermostat question. I just installed my thermostat and the engine starts to over heat and starts to surge when i put in the clutch. Then when i turn the heat on there is absolutly no heat. I shouldnt say "surge" but goes up in rpm and then drops down and then up and then down very fast like it's trying to warm up but then it relizes it's to warm and lowers rpm and relizes it's to cold.
im not sure but can anyone help? And i just replaced my thermostat so it had something to do with that but im not sure if i missed something or what. So please help.
'01 Celica GT
Panther 18's 235/40/18
'93 Honda Civic EX
Injen CAI
Panther 18's 215/35/18
Old 10-24-2006, 04:26 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Is your fan coming on? How is your coolant level? Did you make sure to get all the air out of the system before putting on the radiator cap (after the thermostat change)?
Old 10-24-2006, 07:15 PM
my fan works fine. and my coolant level is fine, but i never let all the air out. how do i do that?
'01 Celica GT
'93 Honda Civic EX
Injen CAI
Old 10-24-2006, 07:56 PM
CivicSpoon's Avatar
There is no Spoon
Take the cap off (when the engine is cold). Let it warm up to where the fan kicks on. Rev the engine a little bit, if coolant is spraying everywhere (out of the top of the radiator) then don't rev it that much. And you should see air bubbles coming out the top of the radiator. A warning though, you're probably going to get some cooling that will spray out, so you might want to put some rags around the top of the radiator. Eventually all the bubbles should be worked out of the system. After that, maybe check your water pump.
Old 10-25-2006, 07:39 AM
I did that and it worked. Thanks a lot dude.
The only reason I changed my thermostat was because it took FOREVER for my car to get warm. So someone told me to change that and i have not tried it out but i am trying to be optomisitc.
Does that sound like something that could be wrong or no? because my friend has a 1.6 mazda mx-3 and his car takes no time to warm up. So i was just tryin some stuff out.
And anyways, would a thermostat for a 92 - 95 work in a 88 - 91 engine? or the otherway around?
'01 Celica GT
'93 Honda Civic EX
Injen CAI
Old 10-25-2006, 01:58 PM
CivicSpoon's Avatar
There is no Spoon
Glad to hear you got it running right. One thing you have to remember is that you have an aluminum block, so it will take quite a bit longer to get it warm. It usually takes my car 2-3 miles before it fully warms up, of course that's starting it up and just going. Not really sure about the compatability. Autozone's web site seems to have some that share the same part # and others that don't, and I have no personaly knowledge on it.
Old 10-25-2006, 06:32 PM
I guess that makes sense, But the problem is that it takes me like 4 - 5 miles to START getting warm. Then after that it raises slow'y but never gets up to the middle of the temp gauge. But my heat is fine.
In one of the posts above, the person said that if it runs cold it will cause the ECU to go into an open loop and cause bad gas mileage. Is there anyway to figure out why my engine isn't getting warm?
'01 Celica GT
'93 Honda Civic EX
Injen CAI
Old 10-26-2006, 06:02 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
Honda engines don't get that warm to begin with. My temp gauge never gets near the middle, usually between quarter & middle. If i'm going down hill my gauge usually bottoms out. I wouldn't worry, I have a 93 Civic EX with 200,000 miles and it gets 37-40mpg and i haven't done a thing to it in 65,000 miles.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 10-27-2006, 07:18 AM
Oh really? Alright sounds good. I thought there was something wrong. do you think the d16z6 gets better gas mileage then then d15b7?
'01 Celica GT
'93 Honda Civic EX
Injen CAI
Old 10-27-2006, 02:06 PM
CivicSpoon's Avatar
There is no Spoon
No, the d16z6 ecu (p28) gives it more gas when it hits vtec. But it also depends on what tranny you're using.
