Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 09-04-2006, 09:08 AM
dougielx dougielx is offline
Coolant temp?
What does everyones coolant temp run? Mine is 210 to 215.
Old 09-04-2006, 12:31 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: Coolant temp?
Sounds OK to me. If you are worried about heat, you can install a 180* thermostat (I think the factory T-stat is 190) and/or a secondary radiator fan.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 09-04-2006, 02:57 PM
Re: Coolant temp?
Thanks, Im new to the olds 98, mines a 1989, just trying to get a feel for the car and the temp everone is running. Pretty impressed with the car so far for a mere $500 lol. By the way, anyone know where the ECT sensor is located, i see two sensors below the tb , a big one and a small one, is it one of these?? Thanks again
Old 09-05-2006, 11:30 AM
Alibi's Avatar
Re: Coolant temp?
Yeah, I used to have an 89 Park Avenue (almost identical, as is my current LeSabre) and it was a wonderful car. $500 dollar special that by the time I sold it I probably had 12-13 hundred in it. But I didn't lose much as I got a little over a grand out of 'er
Anyway, here is a link with some pics of the sensors around the TB http://www.lesabret.com/phpBB/viewtopic.php?t=4054
MAF-is the mass air flow sensor, similar to a MAP sensor I believe
IAC-Idle air control valve
CTS-Coolant temperature sensor (brass-colored thing near the IAC)
TPS-Throttle position sensor, is spring loaded, tells the ECM where the throttle is (captain obvious on most of these)
As long as you keep up with maintenace, these cars will go easily go 300k miles or more...it is usually the suspension that gives out before the motor does. ECT sensor....can you elaborate on what it stands for? I don't recall a specific sensor labeled that but I'm sure there is an equivalent.
-Eric
Old 09-05-2006, 05:21 PM
Re: Coolant temp?
ECT=Engine coolant temp sensor, Thats Ford Mustang sensor lingo, my only car maint experience, all this shit is pretty similar, but my ford runs the old speed density system not mass air. Thanks for your help by the way, im sure to have more questions!
Old 09-05-2006, 07:00 PM
Alibi's Avatar
Re: Coolant temp?
Ahh...engine coolant temp sensor. That would be the equivalent to the Coolant Temperature Sensor (CTS) that is near the IAC valve. Its a big PITA to get at if you have big hands. It is the brass-looking thing to the left and I think a bit lower than the IAC...it is really hard to see looking for it from the top of the engine.
Edit: Yeah, I've owned five (soon to be six) H and C body GM cars from the mid 80s to the early 90's, so I understand not knowing foriegn sensor lingo very well
-Eric
