Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 09-04-2006, 09:55 AM
iamauto iamauto is offline
jdm prelude piston/rod
help- looking for source for jdm parts (wholesale preferably) for friends 93 prelude/ in the business
need now- standard piston (2) and rod (1)
Honda/Prelude/vtec/1993/H22a-1/domed/p13 casting/
Old 09-04-2006, 01:42 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: jdm prelude piston/rod
Check HMO, they have alot of JDM internals.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 09-04-2006, 08:22 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
You sure all that info is right there? Because it's not a good idea to use just 2 jdm pistons in a H22a1 (a usdm engine), this will mess up your compression ratio. The only jdm pistons I've seen for the h22 is the type s ones, which are even higher compression than the regular jdm h22a's. And rods are the same for jdm and usdm, so you might as well just go for the usdm ones, since there's a lot easier to find. Try www.hondaautomotiveparts.com or www.slhondaparts.com for those.
