Old 09-04-2006, 02:08 AM
Topdog1 Topdog1 is offline
98 camaro will not burn out
I need some help on understanding a few things and finding out what i need. I recently bought a 98 camaro with a 3.8l v6 , no matter how hard i try it will not do a burn out..... i have suceeded only twice and both times it was on the same surface. also when it does work only one of the wheels spin... if someone knows why and what i could do please help! thanks
Old 09-04-2006, 08:08 AM
stone_mound_camaro's Avatar
stone_mound_camaro stone_mound_camaro is offline
Re: 98 camaro will not burn out
try putting more air in your tire, or do donuts so you can take some of that traction off those tires. or jus wait til its moist outside
car audio guru...
Old 09-04-2006, 08:21 AM
G-man422's Avatar
G-man422 G-man422 is offline
I believe that your car has an "open differential" which is the reason only one wheele is spinning. For more info about it here is a link. http://auto.howstuffworks.com/differential1.htm
Old 09-04-2006, 09:52 AM
666_speed's Avatar
666_speed 666_speed is offline
Son of Satan
My 3.8 didn't want to do a burn out with the 3.08 gears, it will with the 3.42's now though.
Old 09-04-2006, 11:45 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Welcome on your first pot on AF.
Why would you want to sit still and burn off your tires and wear out your rear end and tire tread?
Does not make good sense to me.
MT
MT
Old 09-04-2006, 01:00 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
MT
Don't forget the other assorted powertrain damage, such as U-joints, transmission, etc.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-04-2006, 02:05 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
my point exactly, only ways i do burnouts is in drag racing
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 09-04-2006, 02:30 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
I buy cheap street tires and am in the process of swapping in a 8.5 rear anyway but I enjoy leaving smoke. I enjoy looking at a black cloud and smelling liquefied rubber and thinking to myself, I did that . Its near orgasmic to me .
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 09-04-2006, 07:32 PM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
i cant get enough burnouts to satisfy me. if i had the money to pay for gas and tires i would burn out 24/7. its great. i actually have a few designated spots where me and some friends go for burnouts and donuts and losin it around turns. but back on topic, yes you do have a open rear end, as gay as it sounds thats what ya got, and it makes it easier to spin that one tire if your turning, turning right i think. but if you turn left and gas it up hard you might be able to conceive a donut. good luck and be smart when you do so
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 09-04-2006, 07:59 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Are ya holding the brake while giving it gas? That'll help hold ya still and loosen up that rear tire. Most V6's (especially stock) just aren't strong enough to brake the tires loose without holding down the brake.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 09-04-2006, 08:03 PM
poormillionaire2 poormillionaire2 is offline
Do the v6's come with the traction control?
If so, make sure that's off, because that could be your problem.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 09-04-2006, 09:19 PM
666_speed's Avatar
Son of Satan
They have a second gear start button that will lock out first gear, but it's a switch that you must turn on, it doesn't automatically come on.
Old 09-04-2006, 10:11 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
is that the srs switch on the dash or is that what the traction control in the v6 is called? i got a friend with a 98 v6/auto and we were both sort of scratching our heads
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 09-05-2006, 12:37 AM
CamaroRS92 CamaroRS92 is offline
I'm not particularly fond of burn outs myself
Back in 86 i had my shiny brand new black IROC Z parked in a lot where i worked and this guy came into the parking lot and started doing full circle burnouts. Well, one of his tires picked up & threw a rock and guess where it went...........Right into my right quarter panel with a nice little dent and a chunk of paint chipped off right down to bare metal.
Old 09-05-2006, 12:41 AM
666_speed's Avatar
Son of Satan
It's the SGS switch, beside the fog lights switch on the dash. It locks out first gear and basically is v6 traction control, it's very handy in the snow haha.
