Old 09-04-2006, 12:42 AM
des7165 des7165 is offline
Send a message via AIM to des7165 Send a message via Yahoo to des7165
Need help kinda new at this. Plz and Thnx!
Ok ppl I am currently building a 94 hatch for street use but i want it to have some hp i don't really want to so do a whole motor swap (unless it's a better route for less) so i decided to just swap the head out and build the engine. I want to swap a vtec head on form the 94 ex coupe on. Now i've heard from a friend that if i do this i will be pushing alittle more than a stock ex engine, something to do with the compression? Not sure if this is true. I was wanting to port and polish the the head and get a 3 angle valve job and drop a new cam in. So ppl what all do need to maxamize the swap and about how much will i be pushing hp and torque? Any ideas tips or help would be great i am kinda new to this. I only want maybe 300hp max also i was thinking of a turbo what are the pros and con of one?
Old 09-04-2006, 12:58 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Need help kinda new at this. Plz and Thnx!
Search for info on "mini-me" swaps(vtec head on a non-vtec block). Check out the FI section and HMT for tons of info on the turbo subject. Just to give you an idea, I have a friend with civic, D15b with Tuner Toys rods + pistons ~ $350, XS power turbo kit ~ $1000, Neptuned ~ $700, and another $1500 - $2000 or so in other parts needed. Dyno'd at 278hp and 232tq to the wheels @ 14 psi. So that gives you an idea of what it takes to make those numbers. It's a reliable daily driver because of the tuning and relativly low boost.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 09-06-2006, 03:37 PM
Sohc Your Face Sohc Your Face is offline
A boosted D-series engine will put out some good numbers. A good example would be the one given by AudioGuy93DelSol. Many people will say that the cost to turbo a D-series is cheaper than any B, H, or K-series swap and that's true. You'll be able to put down more power than a stock B-series assuming you get a really good tune.
