Old 09-03-2006, 11:16 PM
00accord44's Avatar
00accord44 00accord44 is offline
High on Potenuse
Send a message via AIM to 00accord44 Send a message via MSN to 00accord44 Send a message via Yahoo to 00accord44
Soldering?
Okay, so I wanna change the lights in my climate control, clock, and ignition to LED, but it requires soldering. I already did my guage cluster LED and it looks great, but it was direct replacement, no soldering needed. But now that I have it, I'm itching to get the rest done.
I could send my climate control board and clock off to have it done for me, but they'll charge me about $20 + shipping there and back. And I'd rather have the satisfaction of doing it myself.
So my question is, how hard is it to solder succesfully? I don't wanna try it and end up ruining my control board forever. I'm not a complete noob when it comes to modding stuff, I generally DIY stuff through trial and error. But when it comes to electronics, error usually results in no more trials.
So is soldering something I should try to do myself? For reference, I've succesfully installed my HID kit, foglights, swapped out guages multiple times, replaced my door speakers, and taken out my headlight housings more times than I'd like to remember.
To see exactly what I'm talking about Click Here
These are the Directions Or if anybody in the Chicago area is good at soldering, I'd gladly throw the $20 your way to avoid the shipping charges
ECNATSISER AL AVIV
Old 09-04-2006, 01:04 AM
Rbraczyk Rbraczyk is offline
Send a message via AIM to Rbraczyk
Re: Soldering?
Soldering is relatively simple. Whoever did that on that website did a terrible job. You need an iron, flux, and a very thin solder from radio shack. Should run you 20-25 bucks. You essentially need to brush what you're about to solder with flux, to help make the soldier flow. Get the iron nice and hot, and have a wet sponge or paper towel to wipe the iron off on. Take the tip of the solder and touch it against the tip or the iron, giving you a nice bead. bring that down to the two points you are about to conjoin, and the flux will allow it to bridge. Any more questions, hit me up on aim. I'd also practice on suff before you do it on your car parts.
Old 09-04-2006, 03:46 PM
00accord44's Avatar
High on Potenuse
Re: Soldering?
Gracias. Any suggestions on random things I could practice solder? I can't think of any thin metal wire I have around the house. Or I guess I could practice by soldering the iron to something useless like a wire hanger first???
ECNATSISER AL AVIV
Old 09-04-2006, 03:50 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: Soldering?
you can get kits to make little blinking lights, and various similar things. you'll probably find them at your local radio shack. soldering's easy, you can pick it up in about 5-10 mins if you have good manual dexterity.
i learned just by making those little kits, it's kinda fun, satisfying and good practice. you'll be soldering LEDs to everything in no time.
Seatbelts Saved My Life
Old 09-04-2006, 05:48 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Re: Soldering?
anybody try one of those "cold soldering" devices. i've been wondering how they do at the board, or componet level?
Old 09-04-2006, 08:30 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: Soldering?
Those things are the biggest peices of shit, dont get one.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 09-05-2006, 02:21 AM
Re: Soldering?
i agree with getting one of the practice kits. They're pretty inexpensive.
Old 09-05-2006, 07:25 AM
00accord44's Avatar
High on Potenuse
Re: Soldering?
Thanks fellas. I'll be making a trip to radio shack soon. Time to add one more thing to the list of random things I know how to do.
ECNATSISER AL AVIV
Old 09-05-2006, 07:51 AM
ghostrx7's Avatar
ghostrx7 ghostrx7 is offline
Send a message via AIM to ghostrx7 Send a message via Yahoo to ghostrx7
Re: Soldering?
its easy, just remember the solder follows the hot iron. and if hot enough, it melts right it to the board. goodluck.
88 10th anniversary rx7 and company h2.
[IMG][/IMG] [IMG]
atkins streetported 3mm seal engine, act clutch, lightweight flywheel, downpipe, straightpipe, greddy power extreme exhaust, hks ssqv blow off valve, short shifter, tein flex suspension, energy bushings, bonez intake, new brakes, rotors, toyo tires, mazdaspeed replica seats
Old 09-05-2006, 11:49 AM
WickedNYCowboy's Avatar
WickedNYCowboy WickedNYCowboy is offline
Send a message via AIM to WickedNYCowboy Send a message via Yahoo to WickedNYCowboy
Re: Soldering?
Get some Rosin core solder and a Soldering Iron. Get a flux that isn't too thick and your set.
Evan
Support your local volunteer fire department
My Rides:
2003 Ford F-350 Long Horn Hauler
Others:
1999 Toyota Camry LE V6-Dad
2004 Chevy Tahoe Z71-Sister
2004 Toyota Camry LE V6-Mom
Old 09-08-2006, 08:25 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Soldering?
I hav one and I think it works great !
One thing, it uses electricity through the tip, if you solder on electronic boards thiers a chance you can fry electronic parts, I hav ruined more LEDs with it then I can count.
It actually lights up the LED when you solder it with the Cold Heat thing.
They work best with new batteries.
Good Luck
1999 Grand Am SS 3.4 OHV
Old 09-08-2006, 08:52 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Soldering?
remember to get the right value resistor according to voltage otherwise you will burn up your LED's.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 09-08-2006, 11:57 PM
Steel's Avatar
Steel Steel is offline
Re: Soldering?
you can get a butane powered soldering iron if you're worried aobut electricity through the tip. Not to mention you dont have that damn cable hanging off the back getting in the way.
Old 09-11-2006, 09:46 AM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
Re: Soldering?
soldering is really easy, while you're at radio shack, buy some spare wire and practice on that. try not to get a huge goop of solder, it should be thin and strong. other than that, just follow everyones advice. also, you don't need a butane soldering iron, just get the cheapest thing you can find, i doubt you'll notice a difference between them other than heat up time and cool-down time and they won't fry circuits (other than maybe the cold solder device).
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 09-13-2006, 06:45 AM
Igovert500's Avatar
blue + red light magnet
Re: Soldering?
First time I soldered, was putting a chip into my Sony playstation. As said above, it isn't hard. Doing a clean job takes a bit of practice, so in retrospect, I'd practice on 2 wires, before I tried anything on a circuit board. Because if you overflow or anything, it could potentially short something out. But don't be intimidated, it's pretty simple.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
